Help calculating end time based on minutes left
I’ve been breaking my head over this a couple of nights now, but I don’t know how to get this done so I hope someone can help me out.
Goal:
My dryer and washing machine (using the Bosch Home Connect app) have a tag available with “minutes left” (string, format mm:ss) that indicates when the current program is finished. My goal is to calculate the end time of the program using the remaining time from the current time.
For example: The current time is 15:00, remaining time is 30:00. I want to calculate the end time, in this case 15:30.
I’ve been trying with Homeyscript, but if I’m correct, I can’t read tag/variable values in the script.
My guess is I need to use BLL for this, but I don’t know what to do.
Hoping someone can help me in the right direction!
I would suggest to ignore the seconds part from your dryer/washer. Make a flow, that extract the first part of the variable like this:
bilde
(You can use the standard logical card, just get the format right)
Divide the result by 60.
Extract time from now-time variabel, use the whole number value from your previous calculation, add that to the hour time you just extracted.
from your calculation, you got a value after the desimal point, that is the minute part. 60*result gives you minutes. Add that to now-time variabel. After calculation, run it in to a “all” block, then set the time hours and minutes.
You have to make “failsafe” function so you do not exceeed 24 hours and exceed 60 minutes.
If you do your calculations in epoche date and time, that is not a problem. It is supported by BLL.
Thanks a lot! This works. :smiley: I don’t have the failsafe yet though.
@Rmb, I’ll have to look into this. Does this mean that the hours and minutes I extracted in the example of @Marius_Stensrod I all have to convert to milliseconds to use the BLL flow card for epoch?
Yes, to set the endtime 1 hour and 30 minutes later after the current time, use BLL card “set variable to BLL expression “, using the expression
date('shorttime', Date.now() + (90*60000) )
Or
date('hh:mm', Date.now() + (90*60000) )
Which does the same format.
@Marius_Stensrod @Rmb Thanks to you both! This did the trick:
Am I missing something? I do not see that this is Epoch(Unix) time.
And you can remove the number 24 after HH, it should be HH:mm to get the time now with 24hour timestamp.
For Unix time, you can just write “now” in the BLL card, without the quotes. If I understand correctly when it is talking about Epoch time.
See [APP][Pro] Better Logic Library - For Users - #185 by Arie_J_Godschalk
The usage of hh returned a 12h time for me, hence the usage of HH24. Could be that HH returns the same result as HH24. Will check tonight.
When you open de BLL app settings you get all the available formats.
Actually, HH and HH24 are not the same.
30 minutes past midnight with HH will show 00:30, while with HH24 will show 24u30 (some countries write time like that).
