Now I feel stupid. Maybe it’s been like this all the time. Obviously the devices which are logged are the ones that have the setting “log”. They are not active in Armed or partially armed. I thought when I have selected to just log when the surveillance mode is active that those sensors would write to Heimdall dashboard, and not cause the alarm, but when the surveillance mode is disarmed that they wouldn’t be logged…
Great support @DaneedeKruyff! Thanks.
Keep up the good work!
@rindler Devices that have the setting Log will always log regardless of the Only when a Surveillance Mode is active setting(*). This setting is meant to prevent logging from devices with the Partial and Full setting when no Surveillance Mode is active.
(*) With the flow cards introduced in version 2.0.22 and 2.0.23 you can dynamically set the Log setting based on the Surveillance Mode like this:
@Henk_Renting Thanks!
Thanks for your help and explanation!
Hello Danee,
I’m searching for a possibility to check the online state of my ABUS smoke sensors - to see if they are still connected to Homey or the zwave mesh.
I can’t see the time last seen in the development view (Z-Wave) or in the device itself. So I hoped to see the state in your app.
Perhaps this would be a reason to add smoke sensors?
-> see the state like time last seen, only in the devices/state page, not in the settings page (for alerts). I confirm, alers should be independent of arming with Heimdall.
-> check the last seen time with timeline comment like it is possible for motion sensors in the settings page.
So far my ideas…but perhaps you have another idea or app I haven’t ween yet where I can check the sensor state?
Thank you
Ronny
Hello Danee.
Have one question/problem:
(Surveillance mode - SM)
When I change SM in the Homey to Armed then SM in the Homekit also changed for Armed - Everything fine and correct. But when I change Homey SM to the Disarmed, then SM in the Homekit changed to disable, and if I change Homey SM to Partially Armed, then SM in the Homekit changed to Home.
Ill use. Heimdall - ver 2.0,35 and HomeKit Sprut 3.1.0
Maybe you have any solution, or maybe im do something wrong?
Thank for your assistance and your time.
This is exactly what one expects. SM disarmed is OFF. partially armed is Home in HomeKit because the alarm is enabled but only for certain zones because you are still at home and do not want to trigger the alarm when walking around in certain zones (bedroom, bathroom for example).
Yes, I can understand this, but the question is whether it is possible to configure Homey and HomeKit to coincide.
It does coincide, the used terms are just different.
Hello @Gennady
Welcome to the community, thanks for using Heimdall. Homey and Homekit both use their own names describing the Surveillance Modes as explained above, I have no influence on the actual names. If your concern is the mapping between the different modes (last time I looked Homekit used 4 modes and Homey 3) you will have to contact the developer of the Homekit app.
Hi guys
Have been using Heimdall for some days to play around with but now I’m ready to give it the well-known Wife-Test and implement it in our daily routine.
But now suddenly nothing happens when clicking the ‘Surveillance’ device on my app. I don’t think I have changed anything in my config though.
Is this something I have caused - any ideas of how to solve it?
-Kenneth
A simple click just deactivates the alarm.
Make a long click and change the mode in the device mode view.
I feel like a jerk now. Haha. Simply forgot to press-and-hold. Thanks, Ronny.
Hi all,
is anyone facing with 2.0.36 recently on 3.2.1-RC2 issue with Heimdall frozing whole Homey app on Android 9 (debug sent to Ahtom) while being on Devices section and not recognizing live sensor updates until Heimdall restart etc?
If that would help - App debug : 22c182a8-e73b-4e82-976f-2fb89dce77ff
Btw it’s taking more then 30MB memory according to the Developers Insights (33.7 MB / 35 MB etc.)
Last week data (I’m rebooting Homey weekly)
I got the same problem. When i open the heimdall app and i’m on the tap “dashboard” ther is no problem. But when i touch one of the other tab’s (Devices, settings or instructions) the app get frozen. I have to close the intire homey app and restart again.
Usually when I suggest something you have already thought of that functionality, I just don’t understand how to do it. Anyway, I am trying again. Hehe.
I have a group of sensors which I activate logging to with those new flow cards when the surveillance mode is armed. Now I would like to send a notification to the timeline when a sensor which is logged got “tripped”. Does this functionality already exist? For example I would like to get notifications when the sensors in the garage become activated, but not trigger the alarm, when the surveillance mode is armed.
@Sharkys, @Jan_Willem_Visser
I’m afraid that’s something in the Homey App which is outside my control. I’ve never experienced this or seen it mentioned before. The settings pages haven’t been changed for very long.
@rindler
Hehe, I think this should do it:
Hehe. I thought of that flow, but thought it would be triggered by all other Heimdall loglines as well. Will try and see how it works. If it works it would be nice with the local tags ‘zone’ and ‘name’. But will report back if it does what I want.
This should prevent unnecessary msgs in your timeline.
And
Logic: local heimdall device tag
contains
garage(something common used for all garage sensors)
And
Heimdall: status is not disarmed
