[APP][Pro] Heatit Controls app [v4.2.6]
This app adds support for devices made by Heatit controls.
Links:
Heatit Controls Athom app
Heatit Controls Beta Athom app
Supported Languages:
  • English
  • Dutch (partially)
Changelog:
4.2.8
  • Fixed Z-Dim2 dim duration flow
  • Improved error handling on TRM6 and DIN Z-Wave
  • Improved Setpoint and Temperature synchronization on TRM6
4.2.7
  • Fixed Z-Temp3 setpoint issue
4.2.6
  • Fixed ZM-dimmer dim duration flow
4.2.5
  • Minor bug fixes
4.2.4
  • Minor fixes
4.2.3
  • Fixed TRM3 Lifeline bug
4.2.2
  • Fixed icon for Z-Smoke2 AC
4.2.1
4.2.0
  • Added support for Z-Smoke2
4.0.8
  • Fixed 2 issues on TRM6 reported by @AxelS
4.0.6
  • Changed class from “Other” to “Socket” for ZM Single Relay and Z Relay
4.0.5
  • Minor fixes
4.0.4
  • Fixed Meter Reset function for multiple devices
4.0.3
  • New Icons for all devices
  • Added a new powerregulator interface to TRM6
  • Updated WiFi integration
  • Added misc flow cards
4.0.2
  • Added Energy page support for HAN/B and HAN2
  • Added Powerregulator mode for TRM6
4.0.0
  • Added support for WiFi6
  • Added support for WiFi Panel
3.9.7
  • Fixed minor bug
3.9.6
  • Changed so TRM6 and TRM6 DC change Measured temperature based on Sensor Mode parameter
  • Add Meter reset for TRM6, ZM Thermostat and ZM Single Relay 16A
3.9.5
  • Fixed onoff on ZM-Thermostat. Added onoff on Z-TEMP3.
3.9.0
  • Reduces reports from Z-TRM6
3.8.5
  • Fixed Z-TRM6 where only internal sensor are showing under setpoint wheel.
  • Fixed Z-TRM6 missing action flow.
  • Tweaked Z-Han2 accumulated energy.
3.8.3
  • Added support for Z-Temp3
  • Fixed multiple issue regarding the Z-TRM6 Thermostat.
  • The Z-TRM6 now has full support in multichannel. (This will cause issues for users that have thermostats that has been included in a previous version.)
  • Please either Remove and Add the Z-TRM6 fully. Or remove the “1.1” in lifeline then save. Then add “1.1” again. The device should now work as expected.
3.6.5
  • Added support for Z-HAN2
  • Fixed an issue with invalid Flow Card ID on Z-TRM6 causing crashes
3.6.4
3.6.2
  • Added support for Z-Water2
3.6.1
  • Added support for Z-TRM6
  • Changed icons
3.5.0
  • Added support for ZM Dimmer and Zig-Dim
3.4.2
  • Add support for different Z-Smoke battery version
3.4.1
  • Fixed a bug where some Z-Dim2 would appear as generic Z-Wave devices.
3.4.0
  • Added support for Heatit-Leakage Stopper
3.3.0
  • Added support for ZM Thermostat 16A
3.2.0
  • Added support for Z-DIM 2
3.1.0
  • Added support for Z-Smoke Battery
3.0.3
  • Added support for Homey Cloud
3.0.2
  • Z-Din 616 bug fix
3.0.1
  • Update
3.0.0
  • Update to Homey SDKv3
2.7.2
  • Added support for Z-Smoke version 4.2
2.7.1
  • Fix Z-TRM3 communication / association issues
2.7.0
  • Add support for the Z-Smoke AC Smoke Detector device
2.6.0
  • Add support for the Z-TEMP2 Thermostat device
  • Update Thermostat device driver library
2.5.0
  • Add support for the Z-TRM3 Thermostat device
  • Add Meter Reset maintenance action for Z-TRM2fx, Z-Dim and Z-relay
  • Update Homey meshdriver to v1.3.23
v2.4.2
  • Add support for the Z-Push button 4 device
  • Update app for new app store
  • Update Homey meshdriver to v1.3.21
2.4.1 (BETA), Homey SW ≄2.4.0
  • Finalize app and drivers for ‘Energy’ (Homey 3.0.0)
  • Update Homey meshdriver to v1.3.14
v2.4.0 (BETA), Homey SW ≄2.4.0
  • Add support for Heatit Z-Dim rotary dimmer
  • Update Homey meshdriver to v1.3.9
v2.3.0 (BETA), Homey SW ≄2.4.0
  • Fix S2 security handshake issues with Z-TRM2fx, Z-water and Z-Relay that result in Z-wave network stability issues by forcing non-secure inclusion.
    • All users experiencing stability issues with the Z-TRM2fx, Z-Water and Z-Relay devices are advised to upgrade to v2.3.0 and remove and re-include their devices based on the v2.3.0 version
  • Removed Homey 1.x.x mobile interface (obsolete)
  • Add insights logging for the Thermostat state capability
  • Prepared app and drivers for ‘Energy’ (Homey 3.0.0)
  • Update Homey meshdriver to v1.3.6
v2.2.1
  • Fix issue not being able to include the Heatit Z-push button 2 and Z-push button 8 devices
  • Z-TRM2(fx) changed default temperature- and meter-reporting interval from 60 to 900 seconds to prevent Z-wave network lock-up
v2.2.0
  • Add support for the Heatit Z-relay device
  • Add support for the Heatit Z-DIN-616 device
  • Update branding of the app
v2.1.2 (BETA)
  • Fix temperature reporting issues for Z-wave thermostat (FW 1.92), Z-TRM2(fx) and Z-Water
    Note: This fix only works as of Homey SW 2.0.5 ([Z-Wave] Reports from nodes with unknown Command Classes can now be read) and will not be implemented in Homey SW 1.5.x
    Note : Please follow the steps mentioned below to fix the temperature reporting :
    • For already paired devices:
      1. Go to advanced settings, and replace (add if not existing) Homey’s ID 1 with 1.1 in the following association groups used for the temperature reporting:
        • Z-wave thermostat (FW 1.92): Group 3, 4 and 5
        • Z-TRM2(fx): Group 2 and 3
        • Z-Water: Group 11, 12, 13 and 14
      2. For the thermostats, change in the Device specific settings (Sensor settings group), the ‘Displayed temperature’ to the sensor connected (default: floor sensor)
      3. Save settings
    • Alternative option is to remove and re-include the device based on v2.1.2 of the app and Homey SW version > 2.0.5
  • Add temperature changed flow cards for Z-wave thermostat (FW 1.92), Z-TRM2(fx) and Z-Water
  • Update to meshdriver v1.2.32
v2.1.1 (BETA)
  • Add support for the Z-Water regulator
  • Update to meshdriver v1.2.30
  • Note : due to an S2 issue within the Homey Z-wave core, the measured temperatures are not reported for the Z-wave thermostat (FW 1.92) and Z-TRM2(fx) thermostats as well as the Z-Water regulator. When this will be resolved, it is likely that the thermostat will need to be re-included
v2.1.0 (BETA)
  • Add support for the Z-wave thermostat (FW 1.92)
  • Add support for the Z-TRM2(fx) thermostat
  • Add all remaining settings for the thermostats
  • Add Power Regulator Mode action card for the Z-wave thermostat (use at own risk)
Note: due to an issue within the Homey Z-wave core, the measured temperatures are not reported for the Z-wave thermostat (FW 1.92) and the Z-TRM2(fx) thermostats. When this will be resolved, it is likely that the thermostat will need to be re-included
v2.0.2
  • Add support for the Z-Push button 2 and Z-Push button 8 devices
  • Minor (cosmetical) modifications to make the app Homey SW v2.0.0 compatible
v2.0.1
  • Add thermostat onoff state trigger- and condition cards
v2.0.0
  • SDK2 rewrite of the ThermoFloor / Heatit app
  • SDK2 rewrite of the Multireg / Heatit Z-Wave thermostat device driver
  • Update to meshdriver v1.2.28
Note: unfortunately, the set thermostat mode action card will be set to “comfort” mode after this update. The action card will need to be updated manually.
Welcome to the forum and thanks for picking up support! Is there a way to include the Heatit z-push button 4 unsecure, and/or have them send association commands unsecure? Right now I can no longer use associations because fibaro dimmers do not support S2 security and the buttons do, so they do not respond to the associations.
This is really important to me because a) dimming works way better and b) the lights still work when Homey isn’t functioning properly.
Hi Edwin,
Currently it is not possible to choose the security level you choose to include in on Homey.
The secure level is chosen within the code and currently we are planning on following Ted’s code.
Apologies for any inconvenience this may cause.
Welcome! Great to see support from the manufacturer. I second the request from Edwin. Would be awesome. So maybe a suggestion for the roadmap.
Hi @HeatitControlsAB !
Welcome and thank you for continuing the great work TedTolboom has done !
I have 6 Z-TRM3 installed in my home, and they work great.
I was however wondering if you could add a cooling mode to the thermostat. I’ll try to explain my situation : In my house I have a heat pump to produce hot water which is used for the floor heating during winter. In summer however, cold water is injected in the floor, instead of hot water, which helps to cool the house a bit (hardly any house is equipped with A/C in Switzerland). I was therefore wondering if you could add a cooling mode, in which the Heat It Thermostat understands that when I ask for a lower temperature, It should open the valves of the floor heating (cooling in this case) and not close them ?
I hope I’ve been clear enough in my explanation but as English is not my mother tongue, I sometimes fail in translating my ideas from french to English.
Thanks in advance & have a nice day.
Q.
You could solve this with flows. You only need a dry contact for the heat pump, which tells you if it’s cooling or not. Of it’s cooling you have seperate flows that become active.
My problem is not really about creating an automation based on the mode the heat pump is in, it is more of a convenience problem. Right now I have to set the Thermostats to 30‱C during summer, to ensure that the floor heating valves are opened and injecting cold water in the pipes, because they don’t have any “cooling” mode, only a heating mode. As the temperature never gets (hopefully) to 30‱C inside the house, the Thermostats are tricked into believing I want them to open the valves to get to that inside temperature (which is in fact cooling the house)
 The problem is that I cannot regulate how much the valves are opened because the thermostats are always telling them to be fully opened to get to 30‱C.
Hope I was clear enough. Thanks for trying to help anyway :slight_smile:
I get it. :blush:
But I had the same issue and don’t have to trick the thermostats in this way. They can be set at your ideal temperature and since Homey knows if the pump is cooling or not the ‘smart’ stuff happens there, not in the thermostat. But yeah, if you want the thermostat to be the smart part you need a cooling function.
Oh my bad, didn’t know you could do that !
To be honest I wouldn’t even know how to program it, as the heat pump doesn’t communicate with the homey directly. Moreover the thermostat are the one ordering the valves to open or not, I’m not sure that the heat pump is involved in that decision.
That’s one way to do it. Direct communication between valve and thermostat. I also use the Z-Water and thermostats but to know when the heat pump is cooling, I chose to go via Homey. Anyway, if you ever need more information, just let me know!
I have just installed 7 pices of Z-TRM3 thermostats from HeatIt a couple of weeks ago, using the HeatIt app in Homey. There was some small issues, but it was not that hard to get them all up and running. Just had to reinstall a couple of them before they were working as they should. They worked fine for some time, but about a week ago, at the same time as Homey released the new software version 7.1.1, some of the thermostats stopped reporting values to Homey. It might just be a coincidence.
I have tested changing group 1 from 1.1 to 1 and back to 1.1 as mentioned in another post in the forum, but this did not help. I can also see that I am no longer able to go in to advanced settings to do changes on the termostats as they repond with a fault message that it is not possible. I then desided to try to remove one of the thermostats and connect it again, but there is no way that I can get the thermostat to communicate with Homey. I have done this with all the thermostats a couple of weeks back and did not have this type of problem. I have also restarted Homey several times and I have power off the termostats and back on again.
At the moment it looks like 3 thermostats work fine, 3 are not reporting values and 1 that I have tried to reinstall are not possible to connect any more. Also note that there are the thermostats closest to Homey that has the problem and the one I am tying to reinstall are only located 2 meters from Homey.
I find it a bit suspicious that this happened at the same time as software version 7.1.1 of Homey was released, as this also statets the following in its release note: " [Z-Wave] Update send command options for improved stability".
Have anyone else experienced something like this? Any suggestions to what can be done?
I have problems with losing connectivity to my Z-TRM3. It is located in the same room as Homey.
Nodes in the route (2 and 128) does not exist in my network.
Any ideas?
Hello, I have the exact same problem. Also have 7 of them. Occasionally one or more of my z-trm3 thermostats stops responding.
Have you tried switching the circuit breaker off and on? That always helps for me, it instantaneously comes back online again. Also resetting them and including them again fixes it also.
I actually had one go offline, then fixed it with the circuit breaker. Went on a 12 days vacation, and when I was away i checked every day. No problems untill i came back home again. Day two of getting home one went offline again. Almost seemed like when the zwave network starts getting traffic the thermostats get in trouble.
I had only 3 thermostats before, included unsecure and never had any problems. Then now in July i bought 4 more and excluded my old thermostats, included them back with S2 secure and also the new ones. So don’t know if it was after 7.1.1, seems to me it started happen after i included it with S2 secure.
I’ve contacted heatit about it, but haven’t gotten any answers yet
I’ve also seen the problem been mentioned on other forums, like here:
https://forum.z-wave.me/viewtopic.php?t=34277
Do @HeatitControlsAB have any ideas of what is going on here?
I can now see that all of my 7 HeatIt Z-TRM3 has stopped communicating. I used Homey Insight to se the log for temperature values. All of the 7 has stopped reporting values trough the last week. Not at the same time, but it looks like one and one is dropping out and there is not possible to get them back online again. I have switched the circut breakers off and on, restartet Homey and tried to reinstall Z-TRM3. Nothing is working anymore. I have other components communicating on Z-Wave (relays and socket outleets) and this are still responding as normal.
I find it a bit strange that all 7 starts to have issues allmost at the same time.
I am trying to add a Heatit z-push button 8 to my homey pro, but I always get the error message «no compatible homey app found for this unit. A basic z-wave unit has been added to the system», even though the heatit zwave app is installed on homey.
Du anyone have a suggestion what I can try here?
Same here, worked fine for months unsecure, but problematic now on 7.1.1 with S2 secure.
We are currently looking into the issue that has come up with the new version of Homey and we will let you know once we’ve been able to resolve this issue.
I have now been able to get all of my 7 thermostats online again. The solution was to do a full fabric reset of the physical thermostats. Then to do a new installation in Homey. They have been working stable after this. To me it looks like this Homey update 7.1.1 made something hang in the thermostat itself.
I also did a factory reset earlier, still lost contact. I did another factory reset today, this time I entered the code 00000 instead of the one on the sticker so it is now included as unsecure.
