Guest account
I want to turn of a few flows whenever a guest account is enabled/disabled.
For instance, When I push the ‘sleep’ button, our house goes into nightmodus, turning the heating down, and turning off all the lights. But when a guest account is enabled, the guest room should stay on..
I’ve seen screenshots where a “And” card is added tot a flow like “And Guest account X is enabled” to decide the further actions of the flow. But this option is not available in my standard Homey Pro 2023.
Do i need to enable a secret option? or maybe download an app for this to achieve?
Thx
Any (guest) account is selectable in these AND cards, Menne.
Then, you can control the account by using it’s at home/away status as “enable / disable guest” in other flows.
it seems to work, thankyou.
though i wanted to create flow-outputs based on the ‘disabled’ or ‘enabled’ setting in stead of home/away..
thanks
