Still so cool: I have got your whole flow needly connected to all my duplicated devices ![]()
I’ll be a moment adding some stuff ![]()
@Edgar
EDIT, i cannot post a 4th message ![]()
Indeed, and here we go (click three times in the TEF field to select all):
[TEF:FLOWS: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]
You will need to install the Advanced Triggers App.
I have added a sequential execution for all TTS devices:
When music is playing, it will be interupted, but speech will not interupt speech, it will wait and play it once the previous speech is done (and within the one minute timeout).
When you import this flow through the TFE–> import, make sure to select everything according to your own devices.
I have a copylist of your devices, so, those are my device you will see when importing. But names are all the same, so its an easy import for you!
Also, select your user.
All your variables will auto match, no need to do anything with them.
Let me know how it goes!
BTW: When you import the TEF, you create a new flow in the root of your flow-directories. Make sure you disable your own/current TTS Beheer flow.
