Hi. When I connect Homey to Google Home then all devices in Homey are added to Google Home. I want just a few lamps added to Google Home. It is connect all or disconnect all. Is there a solution?
Remove the unwanted after (??)
A single device from Homey cannot be removed in Google Home afterwards. It is connect all or disconnect all.
In the past I could set a device in Homey to āotherā and it will not be added to Google Home. Now all devices are added.
Ah sorry was fast first reaction; based on the fact that I had some speakers which I paired in Google Home showing up in Homey. Those came back to Google Home too. So these ones I removed in Homey indeed.
The devices in Google Home I do not want to see I moved to another āhouseā in Google Home.
Thanks for the tip. I have added a second house in Google Home and I can move the devices to the other house. Quite some work to move 58 devices one by one. Anyways, this solves my problem.
Dank je wel.
Thatās the āmagicā indeed.
