I’m using the Homey support Flic has built-in to its hubs. Advanced flows aren’t listed in the Flic phone app when you want to connect a type of button press (click, double-click or hold) to a Homey Flow. Not just the above advanced flow, but none of my advanced flows appear.
I think you might be referring to the Homey Flic app which is community-developed. It seemed to me the built-in method provided by Flic would be more dependable (time will tell).
I used that flow card because when I went to add a ‘When’ card to start the flow the only options I get are to start it with a parameter…
Did I miss something?
I suspect the above two issues are connected. To initiate an advanced flow, I’m guessing Flic would have to request the user to provide a parameter even if not needed - and that would complicate its UI.
Andy
