Fresh Flow FDX app for Homey: now in final testing
I’m finishing up a Homey integration many of you have been asking for: an app for the Fresh Flow FDX ventilation system (decentralized heat-recovery ventilation). It’s now in final testing before it goes up on the Homey App Store. Fresh is a sister brand of inVENTer, the Volution Germany brand, so I suspect the two systems share the same architecture and the app might work with inVENTer units too, but I haven’t tested that.
Many Fresh Flow FDX owners appreciate the hardware and its heat recovery, but find Fresh’s own app and scheduling rather limited. This app lets you control the entire system locally, directly through Homey, and build smart Flows.
App Features
  • Fully local control via Bluetooth (BLE): Connects directly to the Fresh control panel or unit, with no cloud services required.
  • Arduino BLE bridge support (range extender): As Homey is often located some distance from the Fresh panel, I have added support for an optional DIY Arduino BLE bridge. It is ideal where the Bluetooth signal struggles to pass through thick walls or between floors.
  • Smart Flows & sensor-based control:
      • Control fan speed, operating modes (heat recovery, supply air, extract air, night mode) and the boost function.
      • Combine the app with your existing Homey sensors. For example, automatically increase ventilation when the CO₂ level rises in the bedroom, activate boost at high humidity after a shower, or switch to quiet mode when the house enters night mode.
  • Initially supports nearly all the functions available in Fresh’s own app.
Status & Beta Testing
The app is currently being tested to ensure stable operation in both direct mode and via the Arduino bridge, before it is submitted to the Homey App Store for review.
If you have a Fresh Flow FDX system and would like to test the app early, or if you have suggestions for specific Flow cards, please let me know in the comments.
