Flows don't want to run successfully anymore
A lot of changes happened recently, upgraded to the new iPhone 26 OS , replace my Hue bridge with the pro version. Although yesterday when the iPhone upgrade was done the flows were still working correctly, but today with the new hue bridge my homey pro lost internet connection for some reason.
If I start the flow , nothing happens now, if I go to the device directly via the homey app I can manually control it. When I do the flow via the Web interface, it does work sometimes but now for the past hour not anymore. powered down the new hue bridge and tries things via that way, thought it was interfering a lot with the homey pro but to no avail.
What are the next steps I can do to investigate things ? many thx for the help
You problably need to wait for the next Hue app update. I have the same problem, see thread: The new Philips Hue Bridge - Devices - Homey Community Forum
the new Homey Hue app version should repair the loss in functionality and is supposed to be released at the end of this week.
Found a fix, , I cycled through the Hue Bridge Zigbee channel, and tested the flows again now, all work without issue. Think both were on the same channel and the Hue Bridge Pro seems to be more powerful on submitting power. Went from Zigbee channel 25 to 11 and then to 20.
Nice :+1:
