Flow when sensor has value more than a day
I have the Homey Pro with a couple of BlueTooth Xiaomi MiFlora Plant sensors.
I can create a flow for when a sensor is outside the predefined values (send a push notification). However, if a sensor is outside the predefined values for just half an hour that shouldn’t be a problem (maybe I just watered the plants and so the % humidity is very high the first few minutes)
That’s why I have the following question;
Is it possible to send a push notification ONLY when a sensor is outside the predefined value for MORE than a day?
If someone has a solution,… even if it’s a solution with a variable and two flows… please share.
Kind regards
Roel
Flow1
When humidity value change
And humidity value is greater than yyy
And coundown timer xxx is not running
Then start coundown timer xxx for 24h
Flow2
When humidity change
And humidity value is lower than zzz
And coundown timer xxx is running
Then stop coundown timer xxx
Flow3
When coundown timer xxx reached zero
Then send notification to the gardener
You can find the coundown app in the app store
Thank you @peltsi51, that’s very helpfull!
