Flow for Wemo switch f55
As there is no app anymore for Wemo switches , i made 2 simple flows with an http request to switch it on or off. You first need to get the ip-address of the wemo by installing it via the wemo app.
Switch on the Wemo:
Method= POST
URL= http://xxx.xxx.x.xx:49153/upnp/control/basicevent1
Headers = Host: xxx.xxx.x.xx
Content-Type: text/xml; charset=“utf-8”
SOAPACTION: “urn:Belkin:service:basicevent:1#SetBinaryState”
Body=<?xml version="1.0" encoding="utf-8"?>
<s:Envelope xmlns:s=“http://schemas.xmlsoap.org/soap/envelope/” s:encodingStyle=“http://schemas.xmlsoap.org/soap/encoding/”>
<s:Body>
<u:SetBinaryState xmlns:u=“urn:Belkin:service:basicevent:1”>
1
</u:SetBinaryState>
</s:Body>
</s:Envelope>
xxx.xxx.x.xx = ip-address of the wemo
To switch it off put the SetBinaryState to 0 in the body
Maybe someone can use it :slight_smile:
Hi Herman
Brilliant if it works, I have a lot of Wemo switches to integrate in homey :slight_smile:
How do you get the ip adress of the Wemo?
When instaliing i only see a wifi address.
I found a ip scanner. Now I get this error?
Hi Poul,
It did work until Wemo had some changes on their side. I recently checked again and it’s not working anymore…unfortunately :disappointed:
I’m sorry.
Herman
Hi Herman
Thank you! Well, good effort!
I can connect them to Homey via IFTTT, but it is kind of messy and I want to get rid of IFTTT in the future.
Next try wil be: I got a WEMO bridge which might put the wemos into Homekit, and via virtual devices send on/off data back to Homey, to control them from there.
Or maybe the wemos just need to retire.
Hi Poul ,
I feel the same about Ifttt…it works but not always. And there is always the possibility they make the action “PRO”, so you have to pay. Therfor i’m not trying to use it.
