Flow doesn't work on new homey pro 2023 anymore
Hi all,
I have a flow with some get/put request from the standard logic from homey. This was working fine on my previous homey 2019, but not on the new one. If I adjust anything in this flow I get the following error when I want to save it: "Invalid format for arg ‘speed’ expected ‘[[tokenId]]’ but received ‘normal’
Anyone has a idea why this is popping up, funny thing is that when you test the flow from the begin it does trigger the get/put request and it looks it’s working fine but saving it seems to be a problem.
It is always good to include a picture/screenshot of your flow to make it easier to help you. :slight_smile:
Did you change the GET URL to what Homey 2023 expects?
Hover your mouse over the info icon on the card to reviel the URL.
When I try to change the URL in this card it comes with this error, I even tried to remove de last cards or copy the flow but then the same error appears. This is strange since the same cards with the same URL and ID is working in another flow without any errors when you change something.
I found the issue, for some reason this error pop-ups with the Cast a text to Google card. When I removed this, the flow can be adjusted and saved. The argument has been changed, So now it’s working fine again. Still It would be nicer if the flow was showing something was wrong with that card and not just the error, searching for a needle in a haystack. But thanks any how!
