Flexit Bodo Supreme
Welcome to the official topic for the Flexit Bodo Supreme app for Homey.
This app allows integration and control over the Flexit Bodo Supreme fan directly from Homey.
Homey communicates directly with the fan over the local network using MODBUS over UDP. As a result, automations will still work even if your internet connection is lost.
The goal is to enable seamless control by connecting the fan with your other smart home devices.
Flows
Through Flows, you can build advanced automations. The app offers a wide range of flow cards for Triggers (when), Conditions (and), and Actions (then), allowing control over almost everything the fan does. You can check conditions and perform actions related to:
Motion sensor
Light sensor
Fan inactivity
Air quality
Humidity
Temperature
Automation and Control Conflicts
For the control to work optimally, it is highly recommended to turn off all existing automations and scheduling inside the official Flexit mobile app itself. If Flexit’s own logic is still active, it will start interfering with Homey for control over the fan. By letting Homey handle all logic, you avoid unexpected behavior and conflicts.
Setup Procedure
The fan’s IP address, ID, and PIN are required to connect the fan to Homey.
NB! The PIN must be EXACTLY 4 digits to use the app. If the PIN is not 4 digits, the checksum will be calculated incorrectly, and you will be unable to communicate with the fan.
It is HIGHLY recommended to use a static IP for stability. Do this in your router rather than the Flexit mobile app for convenience.
Note: Ensure that your Homey and the fan are connected to the same local network (LAN) and subnet.
Tip: Cloud Management
In the Flexit mobile app, under Settings > Wi-Fi setup, you will find the option “Allow device management via Cloud Server”. Since this Homey integration communicates directly with your fan over your local network, this cloud connection is not required for Homey to work.
If you prefer full local control, you can safely disable this setting. You will still be able to control the fan and monitor all sensor values remotely from anywhere using the Homey app, even when you are not connected to your home Wi-Fi.
Polling Interval & Updates
Important regarding polling intervals and Air Quality (AQ) sensor accuracy:
Frequent data requests (polling) can cause the AQ sensor readings to rise uncontrollably.
To ensure stable and accurate data, I recommend a polling interval of 90 seconds.
While the app allows you to set the interval as low as 30 seconds if you want to experiment, please be aware that shorter intervals may trigger false AQ readings.
For the best balance between responsiveness and sensor stability, 90 seconds or higher is advised.
However, whenever Homey sends a command to control the fan, the action is executed and updated immediately.
Other fan than Bodo Supreme
The Flexit Fans mobile app supports the following fans: Roomie V1, Roomie V2/Aura, Vario and Bodo Supreme.
In the mobile app, the interfaces between these fans are different. So I doubt this app will work with other fans than Bodo Supreme. It is probably possible to make this app work with other fans than Bodo Supreme. But I only have Bodo Supreme. So I cannot make the app work with other fans.
While developed specifically for Flexit Bodo Supreme, this app is expected to be compatible with the following models as they share the same hardware platform:
  • Blauberg O2 Supreme
  • Duka S8 Wi-Fi
  • Vents Arc Smart
Note: Compatibility with these specific models has not been personally verified by the developer.
Feel free to use this topic to share experiences, ask questions, or report unexpected bugs.
It is much more efficient to gather all feedback in one place so that other users can also benefit from the solutions discussed.
Reserved
I have a couple of Flexit Roomie V2. Do you have a repo I could clone? Want to try to add compatibility for them
Hi! That is a very fair question, and I completely understand wanting to get the Roomie V2 integrated into Homey.
As it stands right now, I am keeping the source code closed. The main reason is that I have a strict rule for this project: I do not integrate, publish, or take on support responsibility for hardware I don’t personally own. Since I don’t have a Roomie V2, I have no way of testing the functionality or troubleshooting if things crash, which means I can’t fully vouch for the product.
Because of this, I don’t have a public repo available for cloning or pull requests.
That being said: If you have the technical skills and want to build an integration for the Roomie V2, you are of course free to create (and potentially publish) a completely separate Homey app for it! That would be a great addition to the community. However, my app will remain focused only on the fans I can physically quality-assure myself.
Fully understandable. I’ll check it out :slight_smile:
Hi, I’ve just installed latest 1.09 on SHS and added a Flexit Bodo Supreme fan (static ip, cloud management off and 4 digit pin). Also doing 90s polling.
Changing features in advanced settings and starting boost works fine from homey.
But only air quality is polled, no temp/humidity/etc are fetched/shown.
App also crashes regularly with high cpu usage.
Example log:
2026-07-18T12:30:04.130Z Homey [log][ManagerAppsLocal][AppLocal:no.flexit.fans] CPU is 30%. Sending CPU Warning 9/12 …
2026-07-18T12:30:14.130Z Homey [log][ManagerAppsLocal][AppLocal:no.flexit.fans] CPU is 30%. Sending CPU Warning 10/1 2…
2026-07-18T12:30:24.130Z Homey [log][ManagerAppsLocal][AppLocal:no.flexit.fans] CPU is 20%. Sending CPU Warning 11/1 2…
2026-07-18T12:30:34.130Z Homey [log][ManagerAppsLocal][AppLocal:no.flexit.fans] CPU is 30%. Sending CPU Warning 12/1 2…
2026-07-18T12:30:34.132Z Homey [log][ManagerAppsLocal][AppLocal:no.flexit.fans] Last 10 lines Stderr:
2026-07-18T12:30:34.132Z CPU Warning Limit Reached
2026-07-18T12:30:34.132Z :warning: The app has crashed.
2026-07-18T12:30:34.157Z Homey [log][ManagerAppsLocal][AppLocal:no.flexit.fans] Exited. Code: 0, Signal: null
What can be the reason?
On my installation/fan I needed to change the “this.CMD_STATUS” request in device.js
from “0106070b21254b6683b9ff03122011100f040e0d” to “0106070b21254b66b9ff03122011100f040e0d” (removed “83”)
This made the temp, speed etc values to be fetched and is now shown i homey.
I also had a issue With a four-second UDP timeout call startPolling(), which immediately started
another fetchStatus() while existing cycles continue. This produced about
1,673 packets in under five seconds and is the likely the cause of the Homey CPU
crashes. Polling should be single-flight and sequential; UDP success/error
handlers must not restart polling, and every timeout, receive timer, and socket
must be cleaned up exactly once. With these changes, the configured 90-second
interval remains stable and all telemetry matches the official Flexit app.
I assume it is not possible to connect Flexit Aura one? :frowning:
