Thanks for the response - being installed in the next few days so will give it a go!
I’ve actually just got around to this.
Connected all 4 inputs to a switch - but only IN1 is switching (red)
Each input individually seems to work if only that is connected but not if all
I found something on another forum that seemed to indicate that Parameter 14 needs to be set to brightness mode for this to work, but I can’t work out how to do this in Homey
I also don’t know that this will work so any other suggestions welcome!
Edit: Value for parameter 14 is apparently 8738 based on post here: http://forum.micasaverde.com/index.php?topic=123955.0
Edit2: I wonder is this just 14,2,8738 in the parameter field? If so, before I do (as need to rewire) would be good to know if this will revert settings that were on before
Hi there,
What happened with your setup here? Did you manage to solve the problem with Homey in the end? I’m having a similar issue with Fibaro RGBW and have tried all sorts with Parameter 14 but still don’t have a solution - the parameter settings just don’t seem to be changing the controller behaviours.
I did get it sorted and it was via parameters
I’m afraid I no longer have my setup as using Home Assistant for my Zwave now so can’t check what it was
No worries. Thank you ![]()
