Fibaro fgs 224 inclusion problems
Your help is very much appreciated!
@Bavoc Athom says the new beta app should fix these issues. Did you try that one?
Good point, I didn’t check the test version yet this time.
So I did and the issues I encountered seem to be solved :+1:
After the last Homey update I included the unit again (after excluding) and now it works properly
Now my FGS-224 works correctly in ON / OFF switch mode on the 2 relays but the “momentary switch” function does not work, the switch remains on, there is no time delay.
Latest Homey update, experimental Fibaro update and re-including the device made it fully functional!
Works well for me with last homey update and official fibaro app.:grinning:
But I had to do pairing again.
The pairing ask now to enter pin code (written on the module)
Hi Eric,
I was also confused about the momentary switch setting, I think this has to do with switch input type, not relay operation.
I think you need to use raw parameters to do what you want (close relay for one second and then reopen)
Ex: 150,1,2 such as @Wilco_Slaats explained in a post above from April 26
Hello Bavoc,
Thank you for your answer, I do not control the raw parameters so to remedy this problem I added a virtual button and created a rule and it works correctly.
THX
