[Feature Request] Microphone support in Dashboards
Feature Request: Microphone Access in Dashboard Widgets (getUserMedia / Web Speech API)
Summary
Please enable microphone access (getUserMedia / Web Speech API) in the Homey Dashboard widget WebView on iOS, Android, and macOS.
Current Behavior
Dashboard widgets run inside a WebView. The APIs are technically present on mobile, but microphone access is blocked at the permission level on all platforms.
This has been verified through a dedicated test widget that logs the full WebView environment on button press:
Platform SpeechRecognition getUserMedia Result
iOS 26.5 (iPhone) :white_check_mark: present :white_check_mark: present :cross_mark: not-allowed
Android 16 (Samsung Galaxy Tab, WebView wv) :white_check_mark: present :white_check_mark: present :cross_mark: NotAllowedError: Permission denied
macOS (Homey desktop) :cross_mark: undefined :cross_mark: undefined :cross_mark: completely unavailable
All platforms report isSecureContext: true, so the context itself is not the problem — the Homey app simply does not forward microphone permissions to the WebView.
What We’re Asking For
Expose microphone access to widget WebViews by making the following changes in the Homey native app:
iOS / macOS:
  1. Add NSMicrophoneUsageDescription to Info.plist
  2. Implement WKUIDelegate.webView(_:requestMediaCapturePermissionFor:initiatedByFrame:type:decisionHandler:) to grant microphone requests from widget WebViews
Android:
  1. Add RECORD_AUDIO permission to AndroidManifest.xml
  2. Implement WebChromeClient.onPermissionRequest() to grant PermissionRequest.RESOURCE_AUDIO_CAPTURE for widget WebViews
Use Case
A voice-controlled smart home dashboard widget. The user presses a microphone button on their dashboard tablet, speaks a natural language command (e.g. “turn on the hallway light” or “water the lawn for 10 minutes”), and the widget sends the recognized text to a local Homey app API.
The app then uses AI to semantically match the command to the correct Homey flow or device and executes it — including setting multiple capability values in the right order (e.g. watering_duration=10 then onoff=true).
The speech recognition itself uses the browser’s built-in Web Speech API — entirely on-device, no external STT service, no data leaves the local network for the speech step.
This would unlock a completely new category of Homey widgets: hands-free, voice-controlled dashboards without requiring any external hardware (no Echo, no Google Home, no dedicated voice hardware).
Why This Matters
  • :microphone: No third-party speech-to-text service required — Web Speech API is built into every modern mobile browser
  • :locked: Privacy-friendly — speech recognition runs on-device and only if a button in the dashboard is pushed.
  • :mobile_phone: Natural fit for tablet-based always-on dashboards
  • :house: Other smart home platforms (e.g. Home Assistant via its companion app) already support this
  • :high_voltage: The fix is a small native code change on each platform — the WebView side is already ready and working
Current Workaround
None within the Homey app. Users must rely on Siri Shortcuts, Google Assistant, or the dictation function in third-party apps (e.g. Teams) to get voice input into Homey flows.
Thank you for considering this — it would be a significant upgrade for anyone running a dashboard-first smart home setup.
:waving_hand:
+1 for this request, with a second use case: a video doorbell / intercom widget. Everything else already works inside a widget: ring event from a Flow, live WebRTC video, doorbell audio (AAC transcoded to Opus through go2rtc) and a door-open action. Only talking back is missing.
Two findings from my tests (Homey app on iOS, Homey Self-Hosted Server 13.5.0):
  • Calling navigator.mediaDevices.getUserMedia({ audio: true }) in a widget does not return NotAllowedError: it crashes the Homey app. This looks like the typical iOS behavior when an app accesses the microphone without an NSMicrophoneUsageDescription entry in its Info.plist.
  • Homey.popup(url) opens an in-app browser where the microphone is granted, even on a page served by Homey (homeylocal.com). But it asks for permission on every call and cannot be closed from script, so it isn’t usable for an intercom.
Adding NSMicrophoneUsageDescription and a WebKit media capture permission handler on iOS (and RECORD_AUDIO + onPermissionRequest in the Android WebView) would unlock both voice commands and intercom widgets.
Thanks a lot for considering it, and thanks @Jan_Tendahl for the detailed write-up!
Until this is supported: the keyboard’s microphone does work in a dashboard widget’s text box (dictation by the phone keyboard, not by the widget), so a widget can still take spoken input that way. That’s how my own chat widget handles it (Cortex AI, I made it): tap the box, use the keyboard mic, and it sends when you stop talking. Not a replacement for real microphone access, but usable today.
