Exporting all Logic variables to MySQL?
Hi!
Is it possible to traverse all my Logic variables and insert them into my MySQL database in an easy way?
Many thanks!
Here’s a way to start:
Or the app
That would work for numeric values, Arie, but string and bool variables won’t be exported I think.
Ah, you might be right Peter!
I have installed the MySQL since earlier and I’m inserting data from my flows into the db. But what I’m really looking for is a (convenient?) way to “flash”-insert/update all of my Logic variables (String/Boolean/Int) ad hoc into the db. So I mirror the Logic variables into MySQL whenever I like to.
I guessing I need a traverse/loop script for all variables and then create a SQL-script with these variables that I will kick off at the the end of the script?
Thanks!
If you use BetterLogic variables, there are multiple ways of exporting them :wink:
Aha, to bad that I already setup all (hundreds) in Logic! :smiling_face_with_tear:
