Any idea why the Energy overview page duplicates the daily production.
I have checked that there is no duplicate data manager or inverter exposed to Homey.
Any idea where to troubleshoot the issue?
the first thing I think (but you say it all reaady that you check it)
Do you have multiple device where you monitoring your PV power?
the app off the provider, own power meter like a between meter like homewizzard.
Yes I can monitor the production from the inverters own app and it is the same as in Homey under the daily production.
Somehow the Energy overview is double and then some.
At the moment I dont have metering, Homey dongle is in the mail.
Using PbtH ?
I think I figured it out by reconnecting the inverter I noticed that the overview adds the daily total to the overview page. Then I checked that the inverter has lost connection to LAN twice. Now 4 times because of my troubleshoot. The overview page is now 4 times the actual daily production.
I think the solution is to figure out why the inverter loses connection to wifi even with excellent signaalia. Might have to run an ethernet to it to make the readings better. Edit: added a picture. Total production is 16kwh, overview is as in the picture caused by the inverter losing connection to wifi and Homey adding it to the total over and over again
At the moment I am not using it.
I just have the Fronius app exposed to Homey energy.
Static or reserved IP address. (is there a IP change)
Open’s a timeless ping to your inverter ping -t (if windows) for a while
Is there a sleep option in the inverter, disable (i have a old inverter what always get to sleep/shut off when there is now production)
I don’t use the Homey energy page (I have the old 2016 version)
Just some Idee’s
