Dropdown menu
I would like to propose the following suggestion for the Dashboard.
Would it be a useful addition to have some sort of dropdown menu available?
What I mean by this is that, for example, if you have 50 different lights in your home and you want to add them to the dashboard, you currently see 50 separate buttons for each light on the dashboard.
This takes up a lot of space.
If there were an option to group all the lights under one button, it would free up space to add other devices or flows to the dashboard.
When you press the button that contains all the lights, a dropdown menu could appear showing all the individual lights. Something similar to the control menu on an iPhone, where you swipe down from the top.
with Homey widget ‘zone’ you can select a zone. within that zone you can select lights.
the cards shows the number of lights on and you can click on it and go deeper.
I second this suggestsion!
I would love to have a dropdown with customizable values that can then be used in a flow. For example, I have a script controlling an RGB light with 12 different setting/programs, it would be awesome if I could choose between these in a dropdown and pass the selected value in my flow.
(Right now I need to enter a number 1-12 to select one, and I never remember which program is what color/effect).
