Were you able to find a way to get the Dreame token for your vacuum? I’ haven’t succeeded getting it for my L50 Ultra.
Is the HA integration really a “Complete app replacement”? Can you no longer use the original Dreame app? I would like to control the Dreame with Homey (possibly via HA), but I would also like to continue using the original app.
You can use both in parallel.
Dreame did complete Matter (over wifi) certification of many devices (L40, L50, D20, X40, X50, X60, Aqua10, Matrix10) in the last few months, and they became listed on MatterDevices on January 17th:
… with as latest addition the Aqua10 on January 15,
… and Matter updates (both firmware and app updates) also seem to be rolling out:
So, curious to see what’s going to happen in the next few weeks.
Bij instellingen, Meer functies, Matter lijkt het nu te werken. Mijn nieuwe 2026 homey staat nog in de doos, maar wellicht iemand die het al kan proberen?
Seems like X40 was added to the overview mid-april last year, and certified in May 2024. And from what I’ve read, Matter support for X40 has been promised but delayed multiple times since early 2025. I haven’t completely lost hope, but not holding my breath either.
Indeed! Also can show a Matter QR code in the app for my Aqua10 via the ‘More features’ submenu. ![]()
Adding it to Homey is as easy as copying the Matter code, and filling it in at Homey’s ‘add device’ flow. Didn’t need to make any change to the Dreame app / device config whatsoever.
Quite amazing to see that out of the box the device class supports quite a lot of if-triggers. From ‘tank is empty’ all the way to ‘pad has been removed for X minutes’ The only ‘then’ action card it currently supports is ‘set modus to…’ with ‘ready’, ‘clean’, ‘mapping’ (typo?).
There is now a dreame app for the none matter devices! I have tested it and it works for my l10s pro gen 2.
@Peter_Heemskerk thanks for heads up! Will try to connect my Dreame later today.
Just added my Dreame to Homey. Happy times!
Thanks for creating this Dreame App for Homey!
Just checked the list and found the new app, and immediately installed it. For context: I run HomeyPro(2026) and I have a Dream X40 Ultra of about 10 months old, running release 4.3.9_1771.
Upon adding a device I had to log in using an email address. Until this point I only had to specify a telephone number for the Android App. So I went to settings in the Dreame app and discoverd I could also add an email address.
Done that logging in to the device in the homey/dreame app got me access to my dreame. It immediately showed with the given name (previously given in the dreame app).
All status info is correct, but the homey/dreame app did not read out the operation hours.
Reading ‘When’ and ‘And’ cards seem to go well, but then:
- giving commands like ‘start cleaning’ or ‘clean “RoomId” with “strong” suction, “medium” water, “1”*’ are giving the error ‘Fetch failed’.
After googling a bit around I got the suggestion to go to ‘More’ → ‘Apps’ → ‘Dreame’ → Settings, and restart the app.
Then it all started working!
So again, thanks for creating this app!
