Dim with 1 button switch
Does someone has a flow to dim with a 1 button switch? For example with the Xiaomi Button switch.
What I want is that when I hold the button it will dim up, if released and hold again within a few seconds; dim down.
Thanks
Hi, I’ve Search for you on this forum:
Does it helps you?
https://homey.app/f/b0Ijtk
I tried that but wasn’t working like I want it to be…
This isn’t what I mean
Then click and hold first up than down.
I found out that when I use relative dim it doesn’t work when binding to the hold function. When I hold it nothing happens, then I release it and it will dim 1x relative. Anyone know what can be the case?
@timvdhoorn with the information from the link iets possible to create the flow what you want have. I’m using the second input from a fibaro dimmer 2 for the dim loop by a hue bulb.
Flow with the action “hold down”:
https://homey.app/f/Foayzk
Flow to dim_down:
https://homey.app/f/i-qyzk
Flow to dim_up:
https://homey.app/f/cmHyzk
Flow to stop transition and change dim-up<>dim-down:
https://homey.app/f/_f4zzk
Tell me when you need some help!
I will try to duplicate it, thanks!
I managed to create something to my likings by your tips, just sharing it here for others.
