New homey bridge user here.
Is it possible deactivate Fibaro motion sensors during certain hours of the day?
The idea is to save battery and deactivate them when they are not needed. The advanced settings allow for night only mode, but i need them during certain hours in the day.
It is asleep 99% of the time, and only wakes up about every 6hours, I think the default time is.
So by the time it wakes up and receives the signal to turn off, you probably already wanted it to turn on again.
Or worse, you need to wait 5 hours for the sensor to be working again.
The thing that needs the most power is sending data to the gateway, e.g. when motion is detected. If motion is detected, the sensor wakes up and sends these datas to the gateway. If no motion is detected, no data is sent to the gateway and the sensor goes into sleep mode.
However, some data are sent to the gateway even without motion, e.g. the temperature and brightness values. For both parameters it’s possible to reduce the number of sendings by adjusting the values (difference values, interval).
The WakeUp interval is there for the gateway to send data to the sensor. E.g. to check if the sensor can still be reached.
And yes, you have to accept that it’s not possible to turn off or deactivate the sensor…
When detecting motion or sending its sensor values it doesn’t even wake-up fully, it is only just enough to send the signal, it can’t receive any data, except for the acknowledgement signal back (very specific, tiny signal) as that would use more power.
On wake-up it stays awake for 10 seconds unless the controller (Homey) responds that it doesn’t have anything in memory for it, so it can go back to sleep immediately.
So yes, it is really asleep 99% of the time.
These are THEN cards from the Philips Hue app (by Athom) right?
This has nothing to do with Z-Wave motion sensors at all or other motion sensor which are directly connected to Homey.
I’m not familiar with the Hue app and the communication between the Hue Bridge and Homey, but I guess if the sensor is disabled, the data will not be transmitted between the Hue Bridge and Homey, or they will be ignored.
I don’t think those will disable the motion sensor itself either, just the zigbee messages are ignored in the Hue Bridge.
Zigbee battery devices sleep too.
It indeed are the hue motion sensors. I tried this action, but couldn’t figure out what happened. It seemed it didn’t do anything. So messages ignored, what does that mean? Sensor stays enabled but…?
