DAHUA VTO2201F-P-S2 IP Villa Door Station / Doorbell/VTO on Homey Pro
I am planning my transition to Homey Pro.
I have a set of DAHUA cameras and also a Dahua doorbell/VTO. I already noticed that the cameras integrate with Homey with ONVIF.
But as for the doorbell, does it integrate well? Can I have all the features, such as pressing a button and opening the door?
Thank you very much
Please add links to the product, put some effort in it.
Thanks!
thank you,
The product is:
Thanks.
It supports onvif, but there’s no app available to have it respond to the button for instance.
You can request for an app here (make sure to login first):
https://request-a-brand.homey.app/boards/request-a-brand
It might be a plan to select a supported doorbell instead though.
Btw,
I can’t see how it can open a door?
In fact, the VTO is associated with an internal monitor (VTH2421FB) and has a power supply to the door that allows it to be opened.
But regardless of this, the Dahua application itself has a button that allows the door to be opened.
Do you recommend any equipment compatible with the Homey that has these characteristics?
This part of opening the door is important/interesting, because it allows me to open the door even when I am outside the house.
PS: the door in question is an access door to the house’s grounds, it is not the door to enter the house itself
I’m interested what you went for in the end. I’m setting up a similar CCTV system and was thinking that if there’s no Dahua app (yet) for Homey that I could use the cold relay alarm connections on the NVR - do you know if the doorbell camera triggers anything on the NVR when the button is pressed, or does it just act like a standard camera?
