Create a loop for geluidsbord
I do have a question.
Within the app geluidsbord, you can add small sounds to the Homey Pro and play or cast this sounds to devices.
Due to the fact this small files (900kb) the sounds are also short in duration (time).
Therefore it should be pleasant, practical and usefeel to play these files and repeat (or loop) them a certain time.
I can not find this option within the soundboard app, or for example the Google Chromecast app.
Is it possible to play or cast a sound and repeat this 99 times? And maybe for some other sounds 10 times. And so on.
And ofcourse I do not want to place the card again and again and again to set this goal.
Thanks in advance for any idea or information regarding this.
Regards,
Steven
Hi @sschot ,
probably this one helps:
How to create a Loop?
I have read and also downloaded the app Loop. I have looked into the cards and try to figure out. But do to the fact that it is with geluidsbord and casting to Goole, I have not figured out how to make it possible.
Perhaps I do understand things wrong, but it seems you can not use existing tags in Loop.
This flow starts a transition after the stopwatch ends
Every time the transition reaches a step a beep sounds on my homey 2019. (7 times, 1 time per second)
with the 8 step the transition restarts itself
(Infinitely until i press a button that stops the transition)
As soon as I am ready, I will try to understand and rebuild. But for this very first moment, I do not understand at once…
Thanks for your solution and your example, highly appriciated!
