Hi, how can I create a flow that doesn’t repeat for 12 hours?
Thanks
Thanks
You disable the flow thas supposed to re-enable the flow ?
Install the Chronograph app.
Between the start of your flow and the following stuff insert a ‘Timer is running’ And card. If it’s running, do nothing. If it’s not running link to a ‘Start or replace timer’ When card set to 12 hours, and then do the stuff that your flow does.
BTW, Chronograph timers survive system restarts
Andy
Yes, that works, the entry (trigger) of the flow will be disabled, but what is inside the flow will be executed.
Oh, nice to know. So you don’t ‘kill’ a flow just prevent it from triggering.
