Maybe anybody knows how to solve this. When I want to slide a widget in my dashboard Homey crashes. It happens when I edit the dashboard en try to slide a widget from one “page” to the next. Also when I use the “>” button it happens…
Most probably only the app crashes.
Can you reveal which phone you use?
It is on a Lenovo Tablet M11. and yes, it is the Homey app on it
Does it occur
- on any other Android device?
- from the moment you started to use the dashboard?
- when no: after a certain Homey update?
- when no: after a certain app update?
- when no: after installing a certain app or app widget?
Guess I found the problem. Homey was also running on a 2nd tablet. Afters shutting that one down the problem was solved.
OK, still it’s odd. It should be possible to run the Homey app on a tablets in every room.
Editing the same dashboard as displayed on other units shouldn’t be a problem imho.
Maybe you just found a bug.
Well, tried it again with the 2nd tablet on and Homey running on it. Same problem…Guess it’s a bug then ![]()
