Compatibility questions
I use a bunch of those on zigbee2mqtt. The units themselves are functioning perfectly (also in a shed). It all depends on the quality of your zigbee mesh, interference, and the brands and model zigbee router devices.
It’s tricky to say, “yes, it works fine on Homey”
It has the Matter logo indeed, but Tuya has a bad name when it comes to not following standards ( very well).
And appearantly manufacturers can sell devices with non-standard Matter functionality. Search for Eve measuring plugs here @ forum.
Which of the 5 apps?
Nerd mode: when posting ali links, you can leave out all brabble after “.html”
In this link this code was added:
?spm=a2g0o.cart.shoppingCartRecommend.3.59fd38da7ckKDG&gps-id=shoppingCartRecommend&scm=1007.13440.426876.0&scm_id=1007.13440.426876.0&scm-url=1007.13440.426876.0&pvid=61508fe6-3fa1-4c7e-896c-3af105707723&_t=gps-id:shoppingCartRecommend,scm-url:1007.13440.426876.0,pvid:61508fe6-3fa1-4c7e-896c-3af105707723,tpp_buckets:668%232846%238108%231977&pdp_ext_f=%7B%22order%22%3A%2218%22%2C%22eval%22%3A%221%22%2C%22sceneId%22%3A%223440%22%7D&pdp_npi=4%40dis%21EUR%2128.87%2126.23%21%21%21233.76%21212.39%21%40211b619a17451685704723264e7214%2112000045578108677%21rec%21FI%21128437593%21XZ&utparam-url=scene%3AshoppingCartRecommend%7Cquery_from%3A)
