Bonjour à tous,
Je viens de mettre en place une HOMEY PRO MINI pour remplacer mon Home assistant vieillissant,.
J"essais desserrement de faire communiquer une carte 16 relais dingtian (carte chinoise) avec Homey. Il n’y a pas Appli sur le store, donc je cherche à la faire fonctionner via MQTT.
J’avoue être complètement perdu dans les procédures et les façon de connecter se type d’appareil.
Quelqu’un a t’il déjà intégrer ces cartes sur HOMEY ?
Merci par avance ![]()
Pour aider, voici la doc MQTT dela carte en question :
example SN is 100
MQTT id:
ETH:dingtian-relay100
WIFI:dingtian-wrelay100
notice: publish default send every 30 second
publish example value
/dingtian/relay100/out/lwt_availability online,offline
/dingtian/relay100/out/r1~8 ON or OFF
/dingtian/relay100/out/i1~8 ON or OFF
/dingtian/relay100/out/relay1~8 {“idx”:“1”,“status”:“OFF”}
/dingtian/relay100/out/input1~8 {“idx”:“1”,“status”:“HIGH”} or {“idx”:“1”,“status”:“LOW”}
/dingtian/relay100/out/ip 192.168.1.100
/dingtian/relay100/out/sn 1
/dingtian/relay100/out/mac bc:34:88:00:00:ff
/dingtian/relay100/out/input_cnt 4
/dingtian/relay100/out/relay_cnt 4
/dingtian/wrelay100/out/lwt_availability online,offline
/dingtian/wrelay100/out/r1~8 ON or OFF
/dingtian/wrelay100/out/i1~8 ON or OFF
/dingtian/wrelay100/out/relay1~8 {“idx”:“1”,“status”:“OFF”}
/dingtian/wrelay100/out/input1~8 {“idx”:“1”,“status”:“HIGH”} or {“idx”:“1”,“status”:“LOW”}
/dingtian/wrelay100/out/ip 192.168.1.100
/dingtian/wrelay100/out/sn 1
/dingtian/wrelay100/out/mac bc:34:88:00:00:ff
/dingtian/wrelay100/out/input_cnt 4
/dingtian/wrelay100/out/relay_cnt 4
subscribe example value
/dingtian/relay100/in/control {“type”:“ON/OFF”,‘idx’:‘1’,“status”:“ON”,“time”:“0”,“pass”:“0”}
/dingtian/relay100/in/r1~8 ON or OFF
/dingtian/wrelay100/in/control {“type”:“ON/OFF”,‘idx’:‘1’,“status”:“ON”,“time”:“0”,“pass”:“0”}
/dingtian/wrelay100/in/r1~8 ON or OFF
MQTT LWT topic
MQTT upgrade topic
/dingtian/relay100/out/upgrade_status upgrading,success,fail
/dingtian/relay100/in/upgrade {“upgrade_url”:“https://192.168.1.9:8070/relay.dtf”}
