Make sure that the module configuration in the Tasmota firmware matches the driver that you’re using to add the device to Homey.
i checked the module. it is basic (1) and the driver selected is tasmota basic. Uploading: 20190530_172603 (1).jpg…
still not finding the device. console after restart:
00:00:05 MQT: Connected
00:00:05 MQT: sonoffflood/LWT = Online (retained)
00:00:05 MQT: sonoffflood/cmnd/POWER =
00:00:06 MQT: sonoffflood/INFO1 = {“Module”:“Sonoff Basic”,“Version”:“6.5.0(release-sonoff)”,“FallbackTopic”:“cmnd/DVES_000000000000000000000000000_fb/”,“GroupTopic”:“sonoffs”}
00:00:06 MQT: sonoffflood/INFO2 = {“WebServerMode”:“Admin”,“Hostname”:“flood”,“IPAddress”:“192.168.1.172”}
00:00:06 MQT: sonoffflood/INFO3 = {“RestartReason”:“Software/System restart”}
00:00:06 MQT: sonoffflood/RESULT = {“POWER”:“ON”}
00:00:06 MQT: sonoffflood/POWER = ON
14:22:36 MQT: sonoffflood/STATE = {“Time”:“2019-05-30T14:22:36”,“Uptime”:“0T00:00:14”,“Vcc”:4.094,“SleepMode”:“Dynamic”,“Sleep”:50,“LoadAvg”:22,“POWER”:“ON”,“Wifi”:{“AP”:1,“SSId”:“Workshop”,“BSSId”:“B0:39:56:7E:3F:A5”,“Channel”:11,“RSSI”:92,“LinkCount”:1,“Downtime”:“0T00:00:04”}}
It looks like you’re using a non-standard MQTT topic setting. The “full topic” setting should be the default value: %prefix%/%topic%/
The “topic” setting can be chosen to your liking. For example, I have this configuration for my Sonoff RF Bridge:
its working like a charm
appreciated. it was the non-standard MQTT topic setting issue. much appreciated
regards
I am reading this topic but it doesn’t solve my problem although it looks I am running into the same kind of issue:
When I try to install the sonoff basic(tosmota) from the equipment ( apparaat toevoegen) i get a screen asking for the MQTT broker hostname/IP
Her i fill the homey IP in ( in my case 192.268.20.11)
the next is MQTTbroker port (1883) pre-filled in
and the I am asked to fille in the MQTT borker username and password (optional).
I don’t fille in these as they are optional
pressing “next step” results in the message
"“MQTT connectie kon niet worden gemaakt”
I have a sonoff basic flashed with tamota 12.3.1
below the infomatio from the sonoff:
Sonoff Basic
Tasmota
| Program Version | 12.3.1(tasmota) |
| Build Date & Time | 2022-12-16T10:28:17 |
| Core/SDK Version | 2_7_4_9/2.2.2-dev(38a443e) |
| Uptime | 0T00:03:24 |
| Flash Write Count | 22 at 0xFA000 |
| Boot Count | 8 |
| Restart Reason | Software/System restart |
| Friendly Name 1 | sonoff01 |
| AP1 SSId (RSSI) | jtb (88%, -56 dBm) 11n |
| Hostname | sonoff01-7567 |
| MAC Address | 4C:EB:D6:B7:3D:8F |
| IP Address (wifi) | 192.168.20.29 |
| Gateway | 192.168.20.254 |
| Subnet Mask | 255.255.255.0 |
| DNS Server1 | 8.8.8.8 |
| DNS Server2 | 192.168.20.254 |
| HTTP API | Enabled |
| MQTT Host | 192.168.20.11 |
| MQTT Port | 1883 |
| MQTT User | sonoff01 |
| MQTT Client | sonoff01 |
| MQTT Topic | sonoff01 |
| MQTT Group Topic 1 | cmnd/tasmotas/ |
| MQTT Full Topic | cmnd/sonoff01/ |
| MQTT Fallback Topic | cmnd/sonoff01_fb/ |
| MQTT No Retain | Disabled |
| Emulation | None |
| ESP Chip Id | 12008847 (ESP8285N08) |
| Flash Chip Id | 0x14325E (DOUT) |
| Flash Size | 1024 KB |
| Program Flash Size | 1024 KB |
| Program Size | 629 KB |
| Free Program Space | 372 KB |
| Free Memory | 26.4 KB |
Does anybody know what I am doing wrong?
They are optional if you configured the broker to allow unauthenticated connections. Have you?
I did not chek the line: authenticatie van gebruikers aanzetten ( Wordt niet aangeraden)
should I do that?
I assume you mean “uitzetten”.
Whether you should do that or not is a personal preference. But if you don’t want to disable it, you need to create a user/password combination and configure your device to use it.
OK, I just checked the checkbok in the broker.
Now I seem to come a bit further: but I now come to a white screen with a turning Wheel
It is asking to (soft) reboot the sonoff ,which I did. and then it says
“no new equipment found”
So you’re using the Sonoff app? That app is deprecated (won’t be developed any further) and only works with Tasmota versions 6 and lower.
You’re going to have better luck with the Tasmota MQTT app.
Ok, This is actually working.!
Thank you so much. This took me three days of experimenting!
