Can not connect to Chatgpt
Can somebody help me with the connection to chatgpt and homey? I did go to the homey website and click the button then i see in Chatgpt that there is a connection. I only can not make a flow, he tells me that he can see the devices he can see the flow oppurtunities but he can not make a advanced flow.
I already tried to Check the connection disconnect and then reconnect.
I think this is an issue on Athom’s side, I’ve read multiple topics about this already. You should contact support here:
Hello, i use it since the beginning without problems, also the flow programming works!
On which device do you use this function? I use it on iOS devices and have the mobile payment version for ChatGPT…is already the Homey Plugin in ChatGPT installed, this should be happen after you have connected Homey with ChatGPT successfully!
