I have been modifying flows, renaming them and ultimately replacing them with advanced flows with the same name.
Now I see in the log messages from a flow that does no longer appear in the list of flows. Could it be possible that the flow is still hanging around somewhere and is still active?
Would there be a way to search for flows from a script?
Thanks in advance!
That doesn’t sound like a good idea to me. I would at least add a trailing “New” or “AF” or whatever to the new Adv. flows
But as you discovered, yea, one can name flows exactly the same
(don’t ask me why).
It’s possible, while Homey only uses the generated flow ID’s, which never are the same.
But, as you can see, when I search for a part of a flow name, it shows both duplicate flows, it doesn’t get ‘hidden’ or something:
You can try this Device Capabilities app flowcard, when you know what card(s) were used in the flow, so it’s able to find any flow with that particular card:
This below should spit out each and every flow:
You can run these commands in Web API Playground
For standard flows:
Homey.flow.getFlows();
For advanced flows:
Homey.flow.getAdvancedFlows();
Thanks for the info. In the meantime I found that it was my bad. Forgot about a flow in a corner
