Calendar in Homey Dashboard - Complete Guide
Hi Christer, It is possible, I got it working with the following steps and changes:
  1. Search for this line of code tomorrow.setDate(tomorrow.getDate() + 2);
  2. Change the line of code to this exact line tomorrow.setDate(tomorrow.getDate() + 7);
You can change the 7 to any days you’d like. Basically the 7 means 7 days. If you want it to be 10 days, change the 7 to 10.
Hope this helps!
@Christer_Havarstein
Hi Goldunexist,
I had this problem as well. The github page contains a issue and merge request from a user called cornevandersteen. He changed the code up and now it works.
Link to Cornevandersteen’s change of code: homey-pro-calendar-widget/calendar.html at 5d7b2f1dc7e8e394a2d4bed5261f73fe3d8eb847 · Scheugma86/homey-pro-calendar-widget · GitHub
Link to Github page and issue: GitHub - Scheugma86/homey-pro-calendar-widget: Minimalistic calendar widget with seasonal animations, German public holidays and relationship-related special days (birthdays, wedding day, monthly anniversaries). // Minimalistisches Kalender-Widget mit saisonalen Animationen, deutschen Feiertagen und besonderen Beziehungstagen (Geburtstage, Hochzeitstag, monatliche Jahrestage).
The screenshot so you can see I got it working with the change’s Corne made :slight_smile:
@Martin_Scheugenpflug what about hiding private events. That would be a great functionality
Can you tell me which line I should replace with which new code? I tried to figure it out using the GitHub link, but I don’t understand how to read it.~~
To be honest you can copy Corne’s whole code and paste it in your document. Only thing you’d have to change is the birthdays, holidays and your ical links.
homey-pro-calendar-widget/calendar.html at 5d7b2f1dc7e8e394a2d4bed5261f73fe3d8eb847 · Scheugma86/homey-pro-calendar-widget · GitHub - > Copy the whole code - > Paste it in your calender.html - > change all the customizables and you’re done :slight_smile:
This looks great!
But I need some help with this, I can’t get it to work.
I’ve done everything in this guide, but my dashboard is only showing Loading…
Do i need to wait for this to load all my appointments or should this take 2 seconds to work.
I’ve checked my links, they all are public.
Checked my location, and that seems to be okey.
Also checked the birthdays.
I did not change the holidays or the time.
Am i missing something?
Thanks for the help!
Got it working with iCloud calendar, integrated in Homey Dashboard as well. I set the number of days to 20 and it shows all future appointments perfectly. Just wondering if I can show events which last multiple days on all these days? For instance for a holiday I make an appointment on the first date and put in the end date.Now it is only shown on the start date, would be nice to have it over all days.
Thanks,
Jeroen
Hi all, I’m having issues running the dashboard on my iPad. Did some debugging and got it pinned down to the proxy request.
VEVENT count=Ø
Colin via corsproxy.io raw preview:
{“error”: "Server-side requests are not allowed on your plan. Upgrade at
Does anyone know how I can fix this issue?
