Calculating time diffence between 2 events in homey script
Hey guys,
I am trying to calculate the daily time difference to determine the rate of light dimming between sunset and dusk.
I have tried a couple of option but all of them seems to have a limitation.
Here are the options I tried and why they failed.
-To calculate the time difference I tried to save the store the time in a variable in better logic app. The problem here is that the time stored in the variable are only the two digits of de 24 hour format.
  • I Tried using mathjs in betterlogic by subtracting “dusk-sunset” but I get weird value as output.
So to sum up I calculate time difference because I cant store the data in flow nor script. And I cant mathematically calculate the difference .
Any tips?
my tip is search this forum for (time) calculation
you could make a Homescript and send two parameters, time1 & time2
convert them to timestamps, substract them, and than you could convert that back to time. or… use my script i posted recently, in Dutch:
var dateParts = '17-09-2013 10:08'.match(/(\d+)-(\d+)-(\d+) (\d+):(\d+)/);
console.log(dateParts); // ["17-09-2013 10:08", "17", "09", "2013", "10", "08"]
source: jquery - Converting a datetime string to timestamp in Javascript - Stack Overflow
Check the Flow Utilities app
Example [APP][Pro] Flow Utilities - #6 by martijnpoppen
Question for Advanced Flows: Is there an option to temporarily suspend a flow?
It’s a bit Off Topic
But, yes, that can be done the same way as in the OLD flows:
I meant a one-card solution
The good old disable a flow also works for Advanced Flows!
Even from a simple flow
