Just a quick question regarding adding devices to homey pro. I am making the transition from smartthings to Homey Pro. Do I need to remove the devices from smartthings, (or any other hub for that matter), in order to add them to Homey Pro?
For Zigbee devices, yes. For WIFI devices, or devices that are controlled through a hub, not neccesarily. If you add a Zigbee light bulb in Homey, it will probably ask you to reset it into pairing/connect mode (it’ll tell you how to do so). This means your light bulb will lose its connection to smartthings.
Ok, Makes sense. Thanks rampage!
