So im in the search for a doorbell which works with nest hubs and homey, it has to give me a live stream on my chromecast devices as nest hubs and chromecast with google tv automatically with flows.
As with the indoor cameras.
My setup for now is the eufy products, which are great products but works poorly with google devices, and has no live view or snapshots avalaible.
What are you guys using?
Have you found a good alternative for Eufy in the meantime? I have the same question… looking for a camera with easy setup livestream in a Homey (may be Sharptools) dashboard.
Same question here! Also have a eufy doorbell. It is a good product. But i want an indoor camera that works with google hub and homey.
Jazeker, het was even een puzzel maar het lukt. Laat maar weten als je nog wil weten hoe.
Yes please. But can you please respond in english so everybody can understand.
To display my doorbell (Eufy) live on my Google Hub when someone rings the doorbell, I did the following.
You see that I am still using a Chromecast stereo, you can replace it with the hub itself, but then you will have no sound through the hub. You can also use a Google mini or a regular Chromecast.
The reason I adjust the volume to 30% twice is because I don’t want a high volume if I increase the volume while watching (you can’t talk, only listen).
Afterwards, create 2 routines in Google Home (household, not personal).
start = action from Homey (mute stereo sound here)
You create these routines for each hub where you would like the images.
The nice thing is that if you were listening to music, it will start the music again after casting.
Greetings
Kenneth
