Backup: Make it possible to store/lock a "Master Backup" for later use
I wish there where a way to store/lock a “Master backup” for later use.
I’m out traveling a lot and when serious errors occurs in Homey or pheriperals when i’m away, the window of 7 days of backup is to small.
Please add a option for storing/locking a Master Backup. I.e by allowing the possibility to store or lock one of the seven day backups as a master backup)
Athom is not represented here in the forum.
But you can contact Athom directly. How? Please read the following post:
You can disable the automatic backup and decide for yourself when you want to create a backup. You can also delete backups that are no longer needed. So it’s your responsibility.
Thank for the link.
Yes, disable/delete backup is the only solution for the time beeing.
Anyway, it would be great if we could be able to create a Master backup.
You can request the implementation of new features trough support@athom.com.
Or use the feature request page
Also visible in the topic of post#2
Please do Request this.
I did request it some time ago, theynresponded they liked the idea.
The more requests, the bigger the change.
Request sent.
Ditto
This would be great. I also need to be able to it …
