Authentication for java webapplication
Hi, I am trying to retrieve device from my Homey Pro data for a java based web application. Please help me to setup authentication for cloud login. I setup a client_ID and client_SECRET via Web API, but Claude tells me I need to get these for “HomeyScript”? I can’t find the project page to do so? Bit stuck at the moment. Is Claude leading me astray? Grateful for help! Your app is registered as “Web App” → only allows browser OAuth redirects Server needs “HomeyScript” → allows password authentication
The Fix (2 Minutes)
  1. Go to: https://tools.developer.homey.app/api/projects
  2. Create new project
  3. Select type: “HomeyScript” ← Critical!
  4. Copy new Client ID & Secret
That isn’t the correct wat to create one. Go here to create an api client:
That is what I used, but I get the error: Error updating Homey sensors: Authentication failed after 2 attempts: The grant type is unauthorised for this client_id
for (let attempt = 1; attempt <= maxRetries; attempt++) {
try {
// Create Cloud API instance (same as setup-homey.js)
const cloudApi = new AthomCloudAPI({
clientId: process.env.HOMEY_CLIENT_ID,
clientSecret: process.env.HOMEY_CLIENT_SECRET,
  console.log(`Attempt ${attempt}/${maxRetries}: Calling authenticateWithPassword...`);
  // Authenticate with username/password
  // Wrap in a promise with timeout
  await Promise.race([
    cloudApi.authenticateWithPassword(
      process.env.HOMEY_USERNAME,
      process.env.HOMEY_PASSWORD
    new Promise((_, reject) =>
      setTimeout(() => reject(new Error('Authentication timeout after 25 seconds')), 25000)
Why are we looking at Javascript code when the post title says “java webapplication”?
Did you import the library as well?
const AthomCloudAPI = require('homey-api/lib/AthomCloudAPI');
Everything you need is explained here:
YES:
  • Vercel Serverless Function: Homey Cloud API Proxy (FIXED v2)
  • This version uses the ACTUAL homey-api library (same as setup-homey.js)
  • but with optimizations for serverless environments
  • Environment variables required in Vercel:
    • HOMEY_CLIENT_SECRET
    • HOMEY_USERNAME (your Homey account email)
    • HOMEY_PASSWORD (your Homey account password)
    • HOMEY_DEVICE_ID_TEMP (outdoor temperature sensor)
    • HOMEY_DEVICE_ID_HUMIDITY (outdoor humidity sensor, optional)
const AthomCloudAPI = require(‘homey-api/lib/AthomCloudAPI’);
// Cache for Homey API session (persists across function invocations in same container)
let cachedHomeyApi = null;
let cacheTimestamp = null;
const CACHE_DURATION = 30 * 60 * 1000; // 30 minutes (conservative for serverless)
  • Get authenticated Homey API with retry logic
    async function getHomeyApiWithRetry(maxRetries = 2) {
    const now = Date.now();
// Return cached connection if still valid
if (cachedHomeyApi && cacheTimestamp && (now - cacheTimestamp) < CACHE_DURATION) {
console.log(‘:white_check_mark: Using cached Homey API session’);
try {
// Quick test to ensure session is still valid
await cachedHomeyApi.system.getInfo();
return cachedHomeyApi;
} catch (error) {
console.warn(‘:warning: Cached session invalid, re-authenticating…’);
console.log(‘:locked_with_key: Authenticating with Homey Cloud API…’);
try {
  console.log('✅ Authentication successful, getting user...');
  // Get user and Homey
  const user = await Promise.race([
    cloudApi.getAuthenticatedUser(),
      setTimeout(() => reject(new Error('Get user timeout after 10 seconds')), 10000)
  console.log('✅ User retrieved, getting Homey...');
  const homey = await Promise.race([
    user.getFirstHomey(),
      setTimeout(() => reject(new Error('Get Homey timeout after 10 seconds')), 10000)
  console.log('✅ Homey found, creating session...');
  // Create session on Homey
  const homeyApi = await Promise.race([
    homey.authenticate(),
      setTimeout(() => reject(new Error('Session creation timeout after 15 seconds')), 15000)
  console.log('✅ Homey API session created successfully');
  // Cache the session
  cachedHomeyApi = homeyApi;
  cacheTimestamp = now;
  return homeyApi;
} catch (error) {
  console.error(`❌ Attempt ${attempt}/${maxRetries} failed:`, error.message);
  if (attempt === maxRetries) {
    throw new Error(`Authentication failed after ${maxRetries} attempts: ${error.message}`);
  // Wait before retry (exponential backoff)
  const waitTime = Math.min(1000 * Math.pow(2, attempt - 1), 5000);
  console.log(`⏳ Waiting ${waitTime}ms before retry...`);
  await new Promise(resolve => setTimeout(resolve, waitTime));
throw new Error(‘Authentication failed: Max retries exceeded’);
Please, at least post code formatted as code (between three backticks), or use the </> Preformatted text button
