I was searching already for some time for Smart Water Monitor, which I would be able to install into water shaft without need of :
plumbing skills
without need of external power supply
can be installed on pipe not on water meter
compatible with Homey or Home Assistant (existing API)
is available in Europe
While there are already some solutions, like Flume | Homey (developed by EdvPol ), which was very close to my requirements, unfortunately I can’t install anything on water meter (it’s forbidden in general), during my research I reach to https://www.myaquaro.com/ (https://www.facebook.com/my.aquaro)
They are planning to enter market via Kickstarter and promised to start delivering first pieces just right after end of campaign. While this may fail as any other kickstarter project, you can starting waiting queue already now.
Not sure how quickly they can implement this and how long the kickstarter will run, but based on how they communicate, what they are promising, it’s sounds very interesting for me.
Note - I’m not affiliated with my.aquaro in any way Note 2 - the risks of joining any waiting list or paying anything in advance. You were warned
Will be great, when/if this will be really existing device, to have Homey integration as well
Please Note: A charging cable is not included in the standard order. The charging cable is available as an add-on with every order or you can use your own to minimize waste.
It should be ultrasonic technology which analyses the flows and learn the patterns of use (so it should estimate which kind of activity you performed). I wonder how precise that “AI” pattern estimation would be but that’s just cherry on the cake.
Read somewhere that the ultrasonic sensor will be able to measure ml (yes, ml!) of change/flow. Unfortunately can’t find the place (Facebook, comment from the founder I guess)
FYI, just in case you did the same mistake like me - today they sent instructions, how to make pledge correctly. So if you are pre-baker, you actually must to pledge 100Euro (and even you do enter credit card info, it’s not being charged yet).
Fantastic (unofficially official ) news, except of Home Assistant, also Homey integration will be included ! (or at least Aquaro is keen on getting to support in place thanks to interest of you - Homey users !)
Yep, I already shared your email address so will share the partners one Anyway, will probably happen later this year but seems they are really committed and keen to make it happen.
Some time in October I checked on them if there will be an open API. They will have MQTT on it so that would make thinks quite simple to integrate with for example [APP][Pro] MQTT Hub - Community version at start.
