Aqara Vibration Sensor sensitivity level
Is there any way to change the vibration alarm threshold/sensitivity? I have two deviecs and find that the sensor only reacts to very hard vibrations. Sensitivity can be changed in Xiaomi’s own smart home gateway/hub but I haven’t found it under settings in homey.
Any suggestions?
Someone knows this? I am also interested
Yes, there is.
I’ve created an issue for it at the apps issue tracker.
Details of how to do it for Home assistant is here:
The original forum post where it was discovered and discussed is in the second link.
The code was gleamed from the Smartthings integration.
Values to set in the ZigBee attribute are 1, 11 and 21 for settings low, medium and high.
Please upvote my issue at GitHub(the first link) if this is an important feature for you too
My Apologies.
In English:
"Hi,
Do you know if this has been implemented? The link to the github is dead"
You also can consider donating €€€ to Ted?
The link to Github has been removed from the App Store. Probably because the Aqara app has been officially taken over by Lumi Technology Co., Ltd. and is no longer public.
Please use the related thread to ask questions about Aqara and Xiaomi products.
Just for info: This link was also removed from the App Store, probably for the same reason. But in the first post of the related thread there is still a donation link .
