Apple Shortcuts and Advanced flows Issues
When using Apple Shortcuts/Home-Automation you can start homey flows with a shortcut or home-automation. Normal flows work fine, but Advanced flows don’t trigger (while there is no explicit error and it seems to execute as normal within the Apple Shortcut app).
I also noticed you can’t yet add a tag to an advanced flow using Apple Shortcuts yet.
Does anyone experience the same or am I missing something?
Same issue here. I think it’s after update the Homey App on iOs.
Might be an issue related to the new Homey and beta app, so i reported it in TestFlight.
same error, advanced flow not working for me in shortcut
I have a same problem. Hope it will be fixed soon.
Is this really an issue or a “feature”?
I mean you can have multiple flows in an advanced flow. Which one should be triggered?
For standard flows it will start them, no matter what trigger is set.
If a feature that used to work but no longer works i would consider it an issue, or an error as others called it above.
As of current this is working again with the latest Homey updates.
Just like normal flows, you can trigger advance flows in Apple shortcuts, Google home automations or other flows within homey. This only works if you set a “Play” card because this will be considered the “default” flow to trigger.
Currently it seems that Apple Shortcuts is showing all (non Advanced) Flows instead of favorite Flows (like i was used to).
I am in the process of creating some new Advanced Flows but it seems that these AF do not appear in the list of available Flows within Shortcuts. Therefor i can’t start AF from Shortcuts. Is this a familiar issue or a new issue?
Maybe you should add the start button to those new A-flows?
Just thinking out loud.
Yes! That solved the issue, thanks!
I started with a card ‘when this flow starts’…
YW!
That’s enough with standard flows indeed.
I’m glad adding the start button helped you out!
