[APP] Tuya - Connect any Tuya device with Homey (by Tuya Inc. / Athom)
I had the same issue. Repaired just one device and all the devices came back instantly. I’ll report it.
Andy
Yeah, I was pretty sure, but it is all just a coincidence…
So, I saw this post on Github: Add energy meter driver and cumulative energy (meter_power) for sockets by lsiddiquee · Pull Request #190 · jurgenheine/com.tuya.cloud · GitHub After that I saw that someone had issues with the Tuya Cloud app. So, I assumed the Tuya Cloud app had an update. And upon checking, I noticed that in my case the Tuya Cloud app just worked fine, but the official Tuya app (the one we’re discussing here) had issues.
I restarted the app, restarted my Homey. But nothing worked. When I got home I repaired one device (which happens to reconnect to the Tuya cloud environment) and everything worked again.
So, it most likely has nothing to do with the issue that someone had with the Tuya Cloud app nor with the pull request. It just happened to happen on the same day. And most important: everything is working again!
I’ve been told that there was an issue with the Tuya cloud causing this, so if it isn’t fixed for you yet make sure to restart the Tuya app and repair one device, that should help.
I’ve had to restart the tuya app daily the last week for anything to work. Am I alone?
Some bug fixes are being worked on
You’re definitely not alone. Good to see that this still has focus from the Athom team!
Are you still working on some bug fixes? The past few days, my coffee was not running when I woke up. Turned out switching the smart plug returns a time out. Restarting the Tuya app fixes it.
So, I have taken the Tuya app along in my nightly routine to get restarted. But again, this morning I had to restart the app.
Yes! We found some bugs on Tuya’s backend, surprisingly enough they are now working with us to fix these bugs
Perhaps they now also see the added value of supporting the vast community of Homey (Pro) users!
Nope. Same issue overhere. Almost everytime I want to trigger my rainbirds via Tuya watervalve I need to restart the Tuya Drenso app before it works.
@Doekse i have a lot off problems with my Tuya devies, they don’t react on anything, it looks like they are online but when you try to use them they don’t react at all.
I now use the cloud version to make sure my most important devies will work.
I really hope there will be an update to fiks these issuses.
Thank you for your work in advance!
