[APP][TEST] Tibber Grid Rewards for Homey
Follow your Tibber Grid Rewards in Homey in real time: what you earn per session, day and month, why your home is or isn’t available, and what your car and home battery are doing.
Unofficial. This app is not made, endorsed or supported by Tibber. It uses Tibber’s undocumented app API, which can change at any time.
Features
  • Live status of Grid Rewards for each home: available, delivering or unavailable, with the reason (e.g. Excess power in the grid, No car plugged in).
  • Earnings for the current session, today, this month and all time, logged to Insights.
  • Statistics: last session, sessions and delivery time today, sessions this month.
  • Car and home battery as their own devices: plugged in, smart control, and for the battery its savings, current activity and next planned charge or discharge.
  • Flow cards for sessions, daily and monthly summaries, amounts passed, long unavailability and more.
  • Dashboard widget and a session history page.
  • Six languages: English, Swedish, Norwegian, Danish, German and Dutch.
Requirements
  • Homey Pro with firmware 12.3 or later.
  • A Tibber account with Grid Rewards. You log in with your Tibber e-mail and password.
Installation
Test : Tibber Grid Rewards | Homey
Live : SOON i hope :wink:
Setup
  1. Add your home: Devices → + → Tibber Grid Rewards → Grid Rewards. Log in with your Tibber e-mail and password and pick the home(s).
  2. Add your car and battery (optional): Grid Rewards → Car / battery (Grid Rewards). The list shows what your home device has received from Tibber, so add the home first.
  3. Add the widget (optional): edit a dashboard, add Grid Rewards and pick the home.
  4. See the history: Settings → Apps → Tibber Grid Rewards shows the last 100 sessions per home and totals per day.
If your Tibber password changes, open the home device and choose Repair to enter the new one.
Devices and values
Home
Value Meaning Insights
Grid Rewards status Available, delivering, unavailable or unknown
Session active A session is in progress :check_mark:
Reason Why, e.g. Excess power in the grid. When the home is unavailable, the car’s or battery’s reason is shown too.
Current session Earned in the session in progress :check_mark:
Reward today / this month This month comes straight from Tibber :check_mark:
Total reward All time :check_mark:
Last session Earned in the last finished session :check_mark:
Sessions today / this month Number of finished sessions :check_mark:
Delivery time today Minutes delivered today :check_mark:
The device settings also show the connection status: connected, reconnecting, login failed or Tibber has changed its API, the last update from Tibber and the number of reconnects.
Car and battery
Value Car Battery Insights
Grid Rewards status and reason :check_mark: :check_mark:
Smart control on :check_mark: :check_mark: :check_mark:
Plugged in :check_mark: :check_mark:
Savings today / this week / this month :check_mark: :check_mark:
Battery activity, e.g. Charging with solar power :check_mark:
Next planned activity, e.g. Discharge at 14:30 (2.5 kW) :check_mark:
Battery details are fetched every 5 minutes. If that fails, the battery shows a warning but keeps working.
Money is shown in Tibber’s currency: SEK, NOK and DKK as kr, EUR as €.
Home
Cards
When Status changed · Session started · Session ended (reward, duration) · Daily summary at midnight · Monthly summary when a new month starts · Reward today / this month passed X · Unavailable for X hours
And A session is active · Status is … · Reward today is above X
Car and battery
Cards
When Status changed · The car was plugged in or unplugged · The battery activity changed · Unavailable for X hours
And The car is plugged in · Grid Rewards is available · Status is …
Good to know:
  • Cards with a reason also have a reason code token (e.g. noVehiclesPluggedIn). Use it in conditions; it does not change with Homey’s language.
  • Reward passed X runs once per day or month when the amount is passed. Unavailable for X hours runs once per unavailable period.
  • Session ended fires up to 3 minutes after the session, because Tibber pays out the last quarter about 40 seconds after it ends. Waiting includes that in the reward.
Privacy and risks
  • Your Tibber password is stored on your Homey (in the device), because Tibber’s app API has no way to renew a login without it. The Home Assistant integration works the same way. Nothing is sent anywhere except to Tibber.
  • The API is undocumented. If Tibber changes it, the device becomes unavailable with a clear message, you get one notification, and the app retries every hour.
How it works
The app logs in like the Tibber mobile app and subscribes to gridRewardStatus over a WebSocket. Earnings per day and session are derived from Tibber’s month total:
  • today = month total − month total at the start of the day
  • session = month total − month total when the session started
This is robust where it matters:
  • Counters are kept per home, so several homes or accounts don’t mix.
  • The day rollover uses Homey’s time zone and works even if Homey was off at midnight.
  • A small downward correction from Tibber is not mistaken for a new month, and a late month reset is still detected.
  • Reconnects use exponential backoff (5 s → 5 min). The app pings every minute and reconnects if nothing arrives for 3 minutes.
  • After a wrong password, login is retried only every 6 hours, to avoid locking the account.
  • Values are only written to Homey when they change: on a real day 404 writes instead of 1,502.
Thanks to JohNan/homeassistant-tibber_grid_rewards, whose work showed how Tibber’s app API is used.
Translations
The Norwegian, Danish, German and Dutch texts were machine-assisted. Corrections from native speakers are welcome.
Thanks, this is the first part which was missging in the homey Tibber app. Another thing i would like to know is at which average kWh price the car is charged during a session.
Cause sometimes the predicted price for tommorow is different than the (unballance) price which is calculated in the session itself.
Is doable but i have to pull the price info from the tibber app or everyone have to add a api key to the officiell API to get that part and use the earning to recalc it to get the actual cost. Have to also take into consideration the value of any solar production usage i gues. Ill add it to my idea list. It is easy to just get the grid reward earning for the car charge. I will see what i can come up with.
Atm im working on adding 2 more widgets (last 7 days ernings and a graph for future home bat. events) and a way to export the history data to a csv file or to clipboard. If someone wants to do their own analysis. A small peek into a future version soon to come. Sorry for the swedish text image but you get the idea. Basecly it will show when tibber is planning to charge or discharge into the future on the home batteri.
What will be in 0.2.0 (Waiting for 0.1.1 to be approved by Athom on the store sins that is the first official version)
Anyway when 0.1.1 is approved i will put 0.2.0 on test i am suspecting there will be some minor fixes needed to it. :see_no_evil_monkey: :hear_no_evil_monkey: :speak_no_evil_monkey:
[0.2.0]
Added
  • A link to the app’s topic on the Homey Community forum.
  • The app settings page shows each battery’s planned charge level as a curve, with planned charging and discharging per quarter, until the end of tomorrow (Tibber’s forecast, updated every 5 minutes).
  • Dashboard widget Grid Rewards – battery plan with the same curve and the current charge level.
  • What the car and the battery have earned: Earned today, this month and in total on each car/battery device, live during a session, and the flow card A Grid Rewards session ended with the device’s share. Tibber only reports the home’s total, so each session is credited to the device that delivered during it (split evenly if both did). On a real day: battery 14.91 kr + car 1.73 kr = the home’s 16.64 kr.
  • Reward yesterday on the home: set at midnight and unchanged all day, so Insights shows each day’s total as one step.
  • Session (estimate) on the home during a session: what Tibber has reported, or the minutes so far × the usual reward per minute for that reason if that is more (Tibber reports with a delay).
  • The time of the last update from Tibber in the status widget, and optionally (setting Show “Updated” on the device) as a value on the home. It is off by default because it is written on every update.
  • The history page shows sessions and reward per reason (excess, shortage, other) for this and last month, and for each session how much Tibber’s settlement added after it ended and when (e.g. “+0.10 kr · 40 s”). The CSV export of sessions has a Settlement column.
  • Plug-in reminder for the car: in the car’s settings, a notification once a day at a chosen time if the car is not plugged in, and the flow card Reminder: the car is not plugged in.
  • Check against the charger: report what your charger or car app says with the action card The charger says the car is …. If it says plugged in but Tibber sees no car for 10 minutes, the car shows a warning and the card The charger and Tibber disagree runs. Tibber’s link to the car has then probably dropped.
  • The battery’s day: hours charging or discharging for Grid Rewards, price control and solar today, and energy charged and discharged today, on the battery and in Insights; the card The battery’s day after midnight; and a table on the history page. The energy assumes Tibber reports average power (W) per quarter, which is not yet verified against a real battery.
  • On the car and the battery: sessions and delivery time today and this month, and its share (%) of what the cars and batteries earned this month.
  • Available today (%) on the home, the car and the battery: the part of the day it was available for Grid Rewards or delivering, logged to Insights. Only time Homey actually observed counts.
  • Records: best day, best session and longest session, for the home and for each car and battery, with the flow card A new record was set. Existing history gives the starting records, so updating does not fire the card.
  • The history page shows which car or battery delivered in each session, with a filter per device, and the records. The CSV export of sessions has a Device column.
  • Cars and batteries get their own icon when they are added (devices added earlier keep theirs).
  • Export of the sessions or the daily totals as CSV from the app settings page, to download or copy. English uses commas and a decimal point; the other languages use semicolons and a decimal comma, as spreadsheets in those countries expect.
  • Translations for more battery activities seen on a real battery: charging at a low price, discharging at a high price, and discharging before expected solar power.
  • Flow cards smart control was turned off and turned on or off, and the condition smart control is on, for car and battery.
  • Dashboard widget Grid Rewards – last 7 days with a bar per day.
  • Daily totals are saved per home (about a year).
Changed
  • The dashboard widgets update as soon as something changes, instead of polling every 30–60 seconds; they still reload every 5 minutes in case an update is missed.
  • Fewer writes: the battery and car keep “available today” in their store once an hour instead of every 15 minutes, and “Updated” is only written when turned on.
  • Internal: what the app keeps per home (history, daily totals, records, reasons, car/battery earnings) moved to its own class, devices are looked up in one place, and date formatters are reused (the day key is computed about 6 times faster).
  • Homes on the same Tibber account share one login and one WebSocket (a subscription per home) instead of one each. Repairing one home also gives the others on the account the new password.
  • Battery details are fetched about 10 seconds after a Grid Rewards status change (at most once a minute), instead of waiting up to 5 minutes. The battery’s activity now follows a session straight away.
  • A battery warning is only shown after three failed polls in a row (about 15 minutes). Short outages at Tibber (“Circuit breaker open”) are logged but no longer flash a warning. A changed API is still shown at once.
Fixed
  • The session history is kept per Tibber home in the app settings, so it survives removing and adding the home device. History from older versions is moved automatically.
