This app adds support for RuuviTag Bluetooth Sensor
About RuuviTag
RuuviTag is an advanced open-source sensor beacon platform designed to fulfill the needs of business customers, developers, makers, students, and can even be used in your home and as part of your personal endeavours. See https://ruuvi.com/ fore more information.
RuuviTag driver
This apps allows integration of RuuviTag (RAWv1 and RAWv2 format) in Homey, allowing to monitor :
Temperature
Humidity
Pressure
Acceleration
Battery (min and max voltage can be changed in device settings)
RSSI
Movement (RAWv2 only) - movement rate can be configured in device settings, and completely disabled
Entering/leaving range : it can be used as a BLE beacon, triggering an event when the device enters or leaves the range. The number of attempts scan can be configured per device in device settings.
Scan duration (how long homey listens for BLE advertisment) and polling interval (how long between two scans) can be configured in app settings.
More functionalities will be added in next versions (support for Ruuvi Station, etc.). If you have any idea or request, please submit your ideas on github.
Status
App is published, here are the links for the stable and the test version
I did not do a proper range test. From one side of the house to the other, or from the garden I have no reception problem. I would say that the max distance is around 15m, may be more, but it depends on many factors (noise,wall, etc.).
It’s in the app preferences. At the bottom right in homey main windows, choose the 3 dots. Then parameters, and at the bottom of the list you can see apps parameters.
@Ethaniael I obeserved the movement alarm is triggered erratically in Homey. Even if there are none (I checked) I get 10 or more in a row. Not sure where these artefacts are coming from
