[APP] ROBB smarrt Z-wave and Zigbee app
I’m using the Homey with about 10 Robbsmarrt devices (Zigbee build-inn dimmers and switches).
Feature request: What I’m missing is a state-change event on the “When” trigger. Now there are only the triggers “turned on” or “turned off” (see pic) availble. It will be great if there whould be an switch-change to trigger to (when the switch either was switched on or off), in the “And” statement we can filter if the device was switched on or off.
It will cleanup a lot of separate flow’s (on and off flow) when this could be added!!
Thanks in advance!
Jorick
Any chance the Robb Zigbee motion/temperature sensor will be added? It looks like a pretty neat device -
I currently got 2 issues
I see a missing translation
And also after every homey 23 update the devices lose connection. A restart of the app fixes the problem till the next update. Anyone got a solution?
Hoi,
Zou het mogelijk zijn om de ROBBshop RGBW afstandsbediening (zigbee) toe te voegen aan de app? Ik weet dat Namron een soortgelijke afstandsbediening heeft weten toe te voegen dus het zou mogelijk moeten zijn. Ik zou er enorm mee geholpen zijn! Anders heb ik voor de kat zn viool zo’n afstandbediening gekocht…
Hello to all!
Today I added a 16A ZigBee In-wall Switch (ROB_200-035-0) and it works fine.
Except the fact that I can’t change the type of device that is connected (it’s a lamp says Homey, but I say it’s a wall outlet)
Is there any way to change this (the option isn’t available in the advanced settings) or is this something a developer could add in a next update of the application please?
Kind regards,
Koen
Hi. Possible to add support for a Sunricher Rotary dimmer.
Model: SR-ZG2835RAC
Zigbee ID: HK-SL-DIM-EU-A
I am trying to get the most out of these wall switches by assigning different actions to the different types of button presses in advanced flows. As marked up in the screenshot (in Dutch) the long press ON (Dimming UP) works, but the long press OFF (Dimming DOWN) does not. I am wondering whether this is by design, a bug in the app, or a faulty device. Hope anybody can help. I also messaged RobbShop directly but no satisfactory answer yet.
UPDATE:
Tested with other wall switch: works as expected.
I’ll report the device as broken with Robbshop.
Hi @hugopeeters @TedTolboom
I know what is causing this issue and the App needs to be updated to fix it.
Previous devices used Zigbee commands:
  • Up
    • Step with onoff
    • Move to level with onoff
  • Down
    • Step with onoff
    • move to level with onoff
Latest firmware version uses commands:
  • Up
    • Step with onoff
  • Down
    • Step
    • move to level
The device no longer uses the with onoff command when dimming down.
I have received a replacement unit from Robbshop and it works as expected. Has firmware version 2.7.6_r26. I did not capture what version the defective unit had.
Glad your issue has been fixed. :smile:
Hi since the last update of the app my zwave dimmers do suddenly not respond anymore they all give invalid node. I also have 3 zigbee dimmers that still work ok. Can ingo back to the older version. This version 2.9.0. Does not work properly.
Ron.
I still have this issue, you too? Dimming down doesn’t work
I am considering the 350 Watt Z-Wave dimmers for my gym. Has the issue above been solved and does dimming work fine?
