[App][Pro] Zwift
Connect Zwift with Homey
Create automations based on your Zwift data.
For example control a fan based on your heartrate/power data.
The following data points are supported:
  • FTP
  • Zwift level
  • Total distance
  • Total distance climbed
  • Total time in minutes
  • Total watt hours produced
  • Bike model
Available when Zwifting:
  • Speed
  • Cadence
  • Power
  • Heartrate
Hi, Is Zwift still supported and/or working for you? I cannot connect to my Zwift account (always shows: No new Homey Device found)
I was exited when i saw there is a Zwift app as I have some automation in my pain cave when I Zwifting but when I try to login I get a timeout error. Do this app still work and active?
@macgeis @jonorland I am not very active on this forum but Zwift is still supported and working. Send a diagnostic report if it’s not working for you.
Here are a Diagnostic report when trying to add Zwift and login: 02c269b7-17a2-423a-b8ea-e032571898e7
Now I am getting the same error as macgeis: ‘No new device found’, earlier I received as well the ‘Timeout’, somehow that changed. Diagnostic report: e9201168-81bd-411a-b685-c3d20bf5f581
I have the same problem. I‘m not able to connect my Zwift account and add a device. I sent a diagnostics report.
@TheDude @jonorland @macgeis : Does it works now for the others?
I made an update to the app which should hopefully solves the problem.
It is currently available in test:
I too get no devices found when trying to connect.
Installed zwift app, go to “add new device” choose zwift, it asks for my login info, then it says “no device found” and everything just falls apart…
Is it broken? I would really like this to work!
Diagnostics
8f90ab39-8537-445f-8eff-47eee04b3ac8
