[APP][Pro] Zigbee2MQTT - Use Zigbee devices via MQTT
It is online (last seen 6min ago). But no changed
I restored a backup. It seems that is ok again.
So currently no need for further investigations :wink:
Thanks
Hi @Gruijter Great app! i also have troubles with zigbee on Homey Pro…
How many Zigbee devices could this connection handle? I currently have about 70 Zigbee devices on Homey and would like to transfer them all to HA and then pair them again via Zigbee2MQTT. Will I introduce other problems, or will this work properly? Thanks!
70 is no issue if you have a good bridge. See first post how to setup a bridge.
Thx!!!
I have HA on an Rpi4.
For now it is running smooth, hopefuly also with 70 devices.
Thx!
151 devices. So far running well
Shouldn’t cause any issues.
Adjust your 2.4GHz wifi and zigbee dongle channels properly, to reduce interference.
Overview of my Z2M + SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2
Great!
Whey did you swich over to zigbee2MQTT and not zigbee on Homey?
YW.
After a few years using Homey I started to experiment with Home Assistant. Amongst lots of other stuff, I just liked to try ZHA and Z2M;
Z2M with its gazillion settings is a bit intimidating at first, but the default settings are great to start with.
It’s rock solid, and it has crucial settings like “Timeout”, which marks devices as “not available, do not search and do not try to use the device” → it’s just incomprehensible Homey lacks this kind of settings and checks.
@Peter_Kawa
Oei, na deze aanpassingen en een herstart van Zigbee@MQTT krijg ik deze melding.
Ik heb een backup terug gezet en nu werkt het weer.
Bedankt!
Does anyone use a Thirdreality smart watering kit with Z2M?
It is supported by Z2M, but does it also work with Homey via Z2M?
Tips or concerns?
Looking at the exposed capabilities at least on/off control by Homey should work. Schedules via z2m will likely not work, but I guess you willnuse Homey flows for scheduling.
Yes, the third reality sensors should be supported in Homey as well, I suppose. So if Homey would detect that the plants need water, Homey could give a trigger to the valve to open and water the plants.
Do you think the water alarm would work as well?
If not working out-of-the-box, do you think you could make it work without having the device, @Gruijter?
I understand, no guarantees and only if you got time, etc. of course… :wink:
Just try. You can always create a PR yourself to add missing functionality :wink:
I wish I had the knowledge to create a PR for your app… :wink:
Well, you probably have seen my first post on supporting devices: ‘if you are willing to donate the (funds for a) device, I am willing to put in the extra effort to integrate it’
Didn’t have to.
We exchanged a remote in the past already… :wink:
Different device :wink:
Really? :wink::winking_face_with_tongue:
New version 3.3.0 is ready for testing: Zigbee2MQTT | Homey
  • Fixed white lights incorrectly showing a color picker
  • Fixed capability titles containing underscores
  • Migrated MQTT client to mqtt.js v5
  • Fixed a crash when bridge info messages lack network data
  • Added optional TLS certificate verification for the MQTT broker
  • Various bridge/device connection stability improvements
