[APP][Pro] Zigbee2MQTT - Use Zigbee devices via MQTT
Hi Lyle,
Got your donation. Unfortunately when searching where to buy one I find out it is not available in EU, and manual importing is too much work and risk for me. I will refund your donation.
Sorry :disappointed_face:
No worries. But don’t worry about the donation. Just keep it please, you do a lot of work with this app which I appreciate.
Wow, thanks for your generous donation! :heart::folded_hands::clinking_beer_mugs:
I don’t have the need for these devices and am in the EU (Netherlands) as well, but…
Perhaps there’s a user outside the EU that can order one and send it to Robin?
Or you order/import it yourself or lend yours to Robin, @Lyle_Jenson…?
I can order or send it to him, however, I am unsure if it will do much good as it is a 120v switch. I “believe” EU is 230, is it not? I am unsure if it could be used there without a EU version. I could do a dump, but I understand it would be a lot of manual labor and I understand not wanting to. I will have to wait to see if the Inovelli App will add the functionality of the multi-zones in at a later date and use the Bridge and Inovelli app when they do. Until then, Home Assistant is good for now, since it works with Z2M on that platform, I just really dislike the complexity of HA, and look forward to switching to Homey.
While you were sleeping I created an new app version. I included mapping the 4 zones to Homey, but since I have no way to test it I can only hope it works :thinking: . If it does work, you are in luck :folded_hands: .
New version 3.2.2 is ready for testing: Zigbee2MQTT | Homey
  • Added more capability mappings
  • Added more flow cards
  • Added more translations
Enjoy!
Yes it is. In that case this might not be a good solution I suppose.
I hope the latest version Robin just released does the trick for you then…
It works, THANK YOU SO very much, all zones show up, and work. I appreciate it so very much. Amazing you got it working without even seeing or testing the device. I am so happy it works.
Again, thank you.
Lyle
Super! Happy my shot in the dark hit the bullseye :partying_face:
Hello, thank you very much for such a fantastic application that makes it easier to integrate Zigbee devices. I have two Tuya PJ-1203A energy meters, and they only provide me with Voltage, LQI, and Last_seen data. I have tried both the stable version and the latest test version.
https://www.zigbee2mqtt.io/devices/PJ-1203A.html
Could you add support for this device? If you need any additional data, please don’t hesitate to ask me.
If this is not the appropriate channel, please let me know, and I will submit the request through the one you recommend.
Thank you very much for your time.
I need to extend the Homey app. See first post of this thread. If you donate (the funds to buy) a device, I am willing to spend effort to try and achieve this.
Perfect, I’ll do it this weekend
I have some occasionally crashes(?) of the app, @Gruijter.
According to the App list in Homey the app is running, but all devices are unavailable.
Restarting the app solves it.
Any idea?
I send you a report with number febc51f2-32e5-4344-8ad1-cb439e83d238
I have been using your app for a few days now. Everything works well. Thanks for all the work you put into this.
When I pair an Aqara contact sensor, it works exactly as desired. However, no icon for the device is loaded. Normally this isn’t a problem, but Homey does not include an icon for a contact sensor by default. Is this something you could create?
Under camera’s and security Homey provides a standard icon for a contact.
Sorry, I completely overlooked this icon.
I do have another question.
I bought a Sonoff Smart Water Valve. This can also read water consumption in the Zigbee2mqtt software. However, when I add it to Homey, I am missing this information.
See first post of this thread what to do if you want a device (better) implemented
Hi Robin,
Hope you can help?
I can´t add a special Z2M device anymore to homey which was before there.. I delete it in homey but can‘t add it anymore. I rebooted the device but no change.
I delete the device in z2m without change.
Complete new added devices are appear in your app.
I recognized there is a mismatch (between the number of devices in z2m and in the homey app. Difference of 2)
I think these 2 devices could be the issue.
Any idea what I can do? I recreate the z2m bridge device with no change.
In z2m itself there seems to be no issues
Thanks
Olaf
What is the last seen timestamp for the 2 missing devices? @owuerker
