How flexible is this app, I have build my openmower robot one based on https://openmower.de/ which is based on ROS, runs on a Pi, 1.7cm accuracy and basically we can do what we want in this, but it uses mqtt inside or can put it on HA or publish it somewhere else.
Hi Simon, I know I had a similar request in the past. This is not doable from a software angle. I came across the belowā¦ donāt know what the underlying issue is why you need to disableā¦ Maybe it helpsā¦
What is it you are looking for? Mowinghours is a metric i show. I can check if it is possible to create a trigger flow that accepts hours lifetime of a blade and trigger it when mowing time is increased with that for a number of hours when it stops mowingā¦
current test update will show Blade Work Hours (if reset has been used, it shows working hours since reset).
There is a flow that you can implement that triggers when above an amount of hours as this is specific to an environment.
Hi Benno, there is no reason why it should be unsupported, I can see that it is supporting mqtt in the productlist that is communicated by worx. Could you check your credentials and if okay do a add device. If no devices found, can you send me the log 1 minute after restarting the app?
Hi, that does not give me anything useful unfortunately. Could you go to the worx app, chose setup and tab log , then copy to clipboard and PM me the contents
