[APP][Pro] Wireless Weather Sensors - Reads data from several brands of wireless weather sensors
Hit means that is signal is received that matches the signature for that protocol. OK means that is passes validity checks like e.g. CRC.
If you have a HP2023, then signal reception/processing is just very bad on that model (compared to HP2019). That would explain your low percentage for Oregon v3. Athom is not addressing this and there is nothing the app can do to fix this. See 433 MHz signal reception processing on Homey Pro 2023 is very poor · Issue #347 · athombv/homey-apps-sdk-issues · GitHub.
I have the 2019 Pro.
Unfortunately this app is broken for me. Even after all I have done the sensor values freezes after some time and the only thing I can do to remedy it is to reboot Homey.
This happened just now and I saw in the app that all sensors were gone from the list under app settings.
As you stated, the app hasn’t changed in a long time. So how can it suddenly be broken? Only the Homey FW has changed, so maybe you should say that is broken.
Well, if an app that is created solely for a specific hardware doesn’t keep up with the hardware I would say the app is broken.
It’s not different from when Apple updates the FW of iPhones. Apps need to be updated to work with the new FW to keep working. No one blames Apple if a phone app doesn’t work after a FW update.
Just so I know, you are not going to look into this issue? You are the app developer right?
I know that app developers aren’t payed from Athom or anyone else, which I think is outrageous, so I would gladly contribute to this app since it’s one of the apps I use most in my system. But I can’t pay for something that doesn’t work for me.
Apps for specific hardware as you mention are for specific devices Homey can connect to. These devices have not changed and neither has the app. They are independent of the Homey hardware - Athom ‘guarantees’ they work the same on all types of Homeys (which is unfortunately not the case). Your issue is not something that can be fixed in the app. Best solution I see at this point is to remove the app from the store to get rid of these kind of complaints.
Well, if that’s your view I’ll guess I’ll have to find a different way to use 433 MHz sensors in my system.
Hej, same here, I noticed that suddenly app stopped to work and values are not more obtained from sensors. I have three sensors and all stopped to work. @Paxman have you find any alternative for 433 Mhz?
I managed to “fix” it. I have entered app settings, changed activity parameter to 60 min, then reverted back to 30 min, and I could see there reading from sensors. After that I’m getting data
Unfortunately no. Just today I dusted off a Fibaro motion sensor to do some testing to see if that could be a suitable replacement for my 433 MHz light sensor, but unfortunately it’s not. I use a temperature sensor as a light sensor (modded by me) and this is the Insight for the two just now:
As you can see the Fibaro is not that sensitive while the modded temperature sensor is much more precise. Is that critical…no, but I really hate straight Insight graphs in Homey since as a user you have no idea if the sensor is dead or if the value has not changed enough to register as a change.
It’s still to soon to be sure…but after gotten an answer from Athom on my support ticket about this issue asking me to test another power supply I tried a third power supply and now my system has been stable for over 24 hours! I’ll hold my breath for a couple of days…but if it runs as is should I will know that the PS indeed was the culprit for me. In that case I will eat crow and apologise to @nlrb. I will also find a way to show my appreciation for the app. :+1:
Sadly it was too soon…the freezing still occurs with a different power supply. I’ll have to wait for the next suggestion from Athom.
When adding wireless sensor there is very little time to capture possible sensor signal. Unfortunately my sensor is located in such way that I can’t force it to sent data. Would it be possible to extend the acquisition time of 433MHz signal for e.g. a minute or longer?
Don’t take this as the truth…but I think that if you just give it some time Homey will “register” the sensor in the background. If you go to “Apps”—>“Wireless Weather Sensors” and then “Configure” you will see all hits from the different 433 MHz sensor protocols that are selected. I think that those are ALL signals that Homey receives, not only signals from sensors that are included in the system.
So what you do is power the sensor and wait for awhile. Then do a “Add device” and include all sensors Homey finds (I have a separate folder for new sensors). Next thing to do is to identify which of the those sensors is the one you just powered among the new sensors. Ignore the rest which can be neighbours sensors or rouge ones. I keep them in the “New sensors” folder so they are not “found” the next time I want to add a new sensor.
Did that make sense? :grin:
Thank you!
Indeed it works as you described. The only problem that I get is that my sensor chooses random ID whenever battery is changed.
Yes, that is a big drawback. However, that is what makes it so that you can have many, many sensors. I have two 433 MHz sensors with dip switches that choses what fixed channel to give the sensor, but that limits the number of sensors to four (I think). With the other channel system there are a lot more channels that are randomised when the sensors are powered.
When I use the random channel sensors in flows I create notes (in the flow) with all important information for the sensor and its function in the flow, since all that disappears when sensors are made powerless. That way it’s pretty quick to fix the flow.
I wish Athom could fix it so that if a sensor is “gone” all the relevant stuff is still stored in the flow so all you had to do is to link the sensor with the new channel to repair the flow. There is some script that does this…but I have never used scripts and IMHO I don’t think that a Homey user should have to resort to that level of “programming” to fix this issue.
There is a “Repair” function for sensors but I have never gotten it to work.
Dear Ramón, @nlrb ,
i do have a homey pro, early 2023, and just bought a Alecto ws 1200 v3.1. This because i needed a new weatherstation and read your app did support this model.
Unfortionaly the two does not connect. Do you know if there is a newer protocol than the Alecto v3?
I still have this issue. Each summer I activate a couple of flows that uses two temp sensors for my pool. To make sure the sensors run all summer I change the batteries and this issue occurs. I try to use the repair function but it’s still the same problem with the error message first, then the sensor is found and lastly a frozen blank screen resulting me having to manually add the sensors. This breaks the flows so I have to manually fix those too.
Has anyone ever gotten the repair function to work? If so, what did you do? If not I think the option should be deleted.
Is this function an app function or is it native to Homey?
It’s becoming increasingly difficult to find equipment (temperature probes, temperature/humidity probes).
Would it be possible to add the new BRESSER 8-Channel Thermo-Hygro Sensor 7009998 to the inventory (and therefore to the equipment seen, recognized, and deciphered).
This Sensor is 433 MHz
And may be by the Cresta / TFA protocol.
Could you please let me know if you need additional technical information to add it to the weather sensor software?
Best regards
It’s becoming increasingly difficult to find TFA 30.3139 (TFA protocol) due to recurring stock shortages..
Would it be possible to add the new TFA Dostmann sensor (30.3255.02 with sonde OR TFA Dostmann sensor Thermo Hygro, 30.3249.02) to the inventory (and therefore to the equipment seen, recognized, and deciphered).
And TFA protocol.
Best regards
I have two old cresta temp/hum sensors with 1,2,3 channel selector behind the battery lid a small display and a red blinking light, fresh batteries. The app on my homey 2023 pro connects with them without any problems, super quick, temperature as display but then never changes the temperature again after that (at least past half an hour).
As far as I know about the functioning of this app, it only recognizes data from a typica protocol coming in, not from a specific device. I see 2 devices with the Cresta/TFA protocol and 2 with the Auriol. The app doesn’t know mark and type number of all four.
So, in your case, when the protocol is programmed correctly in your requested devices, the app has to recognize them.
@nlrb : correct? Or did you program specific devices in the app?
@nlrb: in a previous post you mention something like “pulling back the app from the Homey app store”. Please, don’t do so!!! Your app is highly appreciated. Despite some drawbacks, it works well for me. Sometimes data suddenly isn’t refreshed anymore although the device is connected for some time. But hey, that also can be caused by the Homey hardware, which your app uses to retrieve its data.
So, don’t pull your app back from the Homey app store.
