[APP][Pro] Widgetkeeper - dashboards in your browser + custom widgets
That would certainly be a nice solution :grinning_face:.
I just want to say a huge thank you for all the awesome widgets! Honestly, the sheer amount of them and how perfectly they blend with the Homey design is amazing. Love that they’re still customizable too, so you can tweak things but keep that clean, consistent look.
I’m definitely going to be playing around with this a lot. I just moved and starting fresh again with my smart home setup. Priorities wise… I still haven’t picked out a new dining table, but the tablet wall mount is already ordered because these widgets got me way too excited! :grinning_face_with_smiling_eyes:
Really looking forward to all your new stuff!
Thank you so much for the kind words :slight_smile:
I’m happy to hear the project generating as much excitement from use that I get from building it :slight_smile:
Hi all
I have published v1.2.0 for test in the Homey App store.
Only minor changes since the last “What’s new” - but here it is:
Thanks for this update! Something nice to play around with in the weekend :blush: :sweat_smile:.
Would it be possible to add an option to the new Graph - Lines widget to change the title/name of each line? Like in the Graph - Basic widget. The default titles (device + capability name) can be quite long.
Sure - will do this for 1.2.1. It’s also missing for some other charts.
That widget Copy To is sweet :ok_hand: mahoosive thanks for that one :smiley:
What an amazing app! Especially with the latest additions, it’s now possible to create a really nice dashboard.
Would it be possible to always display live camera feeds without having to click on the image first?
Would it also be possible to make a camera view fullscreen through a Flow?
This way, I could also use my wall-mounted tablet as a video doorbell.
I tested 1.2.0 and I found a way to add the Synology cameras now and also disable the click for livestream behavior, for which many thanks!!!
But also a bug came with it: you cannot save the widget if you do not add a device under “Apparaten > + Apparaten selecteren”. I tried a couple of combinations and the button to edit/add the widget is either not available or greyed out. So only adding Camera 1 and Camera 2 like in the example above does not seem to allow me to add the actual widget.
Hope that makes sense :nerd_face: .
My Nest Hub works! Thanks for this amazing update. Please - never abandon this app! @ThomasRS :heart_eyes:
Widgetkeeper 1.2.1 released for test
Cameras
  • Fixed: a widget can now be saved with only Camera 1 to 6 filled in
  • The Devices list is gone in the Homey app; Camera 1 to 6 now come first
  • Existing widgets keep their cameras until you fill in any of Camera 1 to 6; then only those show
Charts
  • Lines, Stacked, Ranking and Timeline: name each value yourself
  • Basic, Lines and Stacked: the legend can be hidden
Thanks for reporting! Try out 1.2.1 I just released.
I can easily implement auto-start for one camera per widget, but not multiple. That would be a bigger rewrite. Also I’m not sure the Homey would handle many streams at once well.
As for full-screen popup I can add this to the popup widget and allow it to show a stream too. But full screen will only work on web dashboards.
Thanks for adding this :grinning_face: !
Another suggestion for a future version: some graphs offer a choice of where to place the legend (above or under the graph). But not all of them, e.g. de daily profile. Could you add this option to all graphs?
Yes, will fix this in 1.3.0 (already in the works)
Hi again, and thanks again for all the effort you put in.
I’ve got another request/suggestion.
The possibility the set a long refresh timer on cameras, or even better: control refresh with flows.
My use case is that I got a couple battery powered cameras, and updating once per minute drains a lot of battery. I’d like to have them on a dashboard to easily access live-stream on click.
In my case it would be enough to update the images a few times a day (to somewhat reflect day/nighttime) just to show which camera is which.
Sure - will do this for 1.3.0
I’ve submitted 1.2.1 for certification so we can get it fully live.
1.3.0 is already in the works - will post a “What’s new” when I can post it for testing.
GM Thomas,
Could you also implement the device names for the Flow Buttons?
THX Chris
Sure - will do this for 1.3.0 that will be up a bit later today.
